No Traction for the Minid Candy 545i
Hi Friends:
I went out about 1:00 p.m. last night for my first timed pass of the season. Well, no luck. Despite no brake torquing, I had no traction at all. I spun all the way through 1st no matter what I did (except see below). I managed a 13.85 @ about 105 and 5.5 (to 60). It was a less than 40 F, but I am at 1600'. Given these observations, my times and speed, adjusted for weather and to 500', would be a bit better than my raw data suggest, but still nothing to write home about.
I suspected that that Progman 23.whatever had turned my car loose again. I am glad to have my wheel spinability back, but now I'll have to work on harnessing the power again with DSC and DTC off. For fun, I tried one pass with both on. The car started out like it was running on four cylinders, but then when the power was released it started spinning--which I didn't expect. No more tries until after 1/10/07. I am looking forward to seeing if I can control the wheel spin enough to do any good.
I am back to wishing that I had stayed with 18" wheels, with light-weight BBS wheels, so I could run drag radials. I think I would have seen some exceptional times last night under these conditions.
Happy holidays to all.
My Ride: 2008 550I,manufactured 2-27-08,delivered 4-2-08.Platinum bronze,natural brown interior,light poplar trim,cold weather package,heated rear seats,HD radio
Originally Posted by Znod' post='369497' date='Dec 20 2006, 11:39 AM
Hi Friends:
Sounds like your low end power is now better than ever Zman.With proper launch I am sure you will get under 5 secs 0-60 raw numbers.
Right on bro, except for the raw < 5.0 part. I think the altitude is too much of problem. Still, in the old days I had a few less than 5.1 as I recall. I think I had a 5.09.
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
Znod,
A little bit off topic but have you read the 545i vs 335 thread? http://forums.e60.net/index.php?showtopic=34699
Go to the e90post link in the thread. Quite amusing.
PS2s running in cold weather are probably going to run like Flintstones - hard as a rock. The rubber compound on any high performance summer tire is not going to get much grip at temps under 40. Try some winter shoes ... they will feel like bubble gum at those temps.
Considering the rubber handicap, those are nice times.
DetailersDomain
Detailing Forum
09-22-2015 03:59 PM
