No heater
My Ride: E60 2006 sedan auto
So I am having trouble with my 2004 E60
I have another thread with the over heating issue that seems to be resolved but now I have no heater in the car at all
First let me tell you what I know from tested and then I would really be interested in others input
So I have no light working in the drivers side (RHD) climate control switch (photo attached)
I have a fan working from the center fan control
But I have no heat on either side of the car
No fuses are blown
All the computer temperature controls are turned to high
But still only cold air
Any advice or questions?
No fuses are blown
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
What's going on E60. I would check to see if your heater core is operating correctly. Mine went out a few years back and it took me a month to figure out it was the core because only one part solenoid went out. Also check for IHKA errors. The no lights on the driver side seems fishy to me. LoL. I have no idea we're to start with that. I'll do some research and let you know what I come up with.
Hi
The only fault code I have is that the ACU sensor is faulty
But I'm not sure if this effects temperature control
I read that the dash temperature control switches can burn out but before I buy a new one I would like to check all the other areas that could be the problem
It's freezing in my car so I hope I can find the problem fast lololol
I hope life is good for you
Well more drama lololol
So I bought a new heater solenoids and put it in and of course I though I would be able to warm my old Bones but still no good
So it seems it must be an electrical problem
Maybe a heater. Relay?
I see there is one under the hood on the passenger side in the sealed electrical box
I checked all the fuses and they are okay
The other way is just to bypass the electrical and put a positive line directly to the switch to see what happens
But I would like to find the problem
Model Year: 05 530i
Engine: 3.0 M54
There has to be another error. The ACU does not matter in my mind. Mine has been bad for 7 years. I don't use it anyway. I'll check a couple other things. Try and do a reset on the car. Unplug the battery for 30 mins. You say you have no light on the control unit. Has it been fixed, I see lights. Also check in INPA with the car a operating temp to see how hot the car gets. Does the cooling fan turn on? Is there any air in the system? Some things just to ensure we are working with the little things checked
gman6262
02-04-2015 11:58 AM
