Modifications to e60 in 2005
Old 12-14-2004, 11:35 AM
  #41
igor's Avatar
My Ride: 535D
I understand that safety modifications are already done...
I doubt that LEDS cud be significant reason for such a delay of M5 launch...
New engines do not concern M5 at all.
Old 12-14-2004, 12:24 PM
  #42
530iii's Avatar
My Ride: E60 "Stripper" Now C6 "Stripper"
Originally Posted by EBMCS03' date='Nov 28 2004, 04:49 PM
[quote name='Francois' date='Nov 28 2004, 04:38 AM']I can give you the answer. If your VIN/FGSTNR is WBANA72080 B790822 or higher you have the modifications.? If lower you have not.? I think that is production date middle of november 2004 or later.
[snapback]61512[/snapback]
Nope.. that VIN number goes against the traditional BMW VIN sequence... well the important part of the VIN isnt traditional...
Digit 8: which tells us the restraint system is a 0 it should be 1 to 5... I have a 5 in mine...
Digit 10: Tells us what year the car is... it has a 0 I have a 5 telling me its a 2005
Last 6 Digits: Is sequential but Its waaaaaaaaaaaay off from my VIN and my cars a Nov 11 2004 Build...
Can anyone else check their VIN to varify how accurate this decoding system is?
[snapback]61686[/snapback]
[/quote]
Hey my digit number 8 is a 5 which is not listed!
My digit number 11 is a C (What plant code is that?) also not listed what gives?
Old 12-14-2004, 12:26 PM
  #43
530iii's Avatar
Originally Posted by EBMCS03' date='Nov 28 2004, 05:36 PM
[quote name='Francois' date='Nov 28 2004, 03:13 PM']My vin is B610901 and its build august 11th 2004. So that would mean that there are 179921 cars build after mine since the modifications in about 3 months. If your correct that would be a lot of E60's in such a short time.
But it clearly states that the modifications have be there since:
VIN and date when rating applies WBANA72080 B790822
[snapback]61689[/snapback]
Humm thats odd... see my VIN is B088XXX, I wonder if its because mines a US car... making the LHD and RHD numbering different... either that or it has rolled over already!
What is your 10 digit? a 4?
[snapback]61693[/snapback]
[/quote]
August 11th 2004 build? I thought the plant is closed for the entire month of August!
Old 12-14-2004, 12:35 PM
  #44
m630's Avatar
[snapback]69064[/snapback]
the safety features were not completed prior to the pre-production of the M5s that are being used in the promos, and shows etc, so that was PART of the delay with the M5
then, what I said was that whatever external change is happening to the MY06 E60s is going to be incorporated into the M5, and this was also PART of the reason for the M5 delay, and this is out of the President of M-Division's mouth, not mine, anyone can read his interview if you like
finally, I said that in the early spring, the E60 will get new engines, and there has been talk that BMW may bump up the model year due to this. If this happens, then we will see the external change in the spring as the new cars in the US would be MY06's
Old 12-14-2004, 08:35 PM
  #45
EBMCS03's Avatar
[snapback]69078[/snapback]
Ya my 8th digit is a 5 also... that i'm guessing is the even NEWER restraint system... Seat Belts, Dual Stage advance front airbag and SIDE AIRBAGS
Plant code C??? that i dont know.
Old 12-15-2004, 12:07 PM
  #46
joepoole's Avatar
My Ride: '05 545i(Build 10/04)(SMG)Sport,BlkSapphire,Blk,Anthricite,Logic7,CWP,Comfort Seats,Nav,RearBags,Shades,Sirius,Heated/SplitFoldingRearSeats; '18 540i xDrive, White/Mocha, CWP, DAP, DAP+, Lux. Pkg, Prem. Pkg., Executive Pkg., Luxury Seating Pkg
Model Year: 2005,2018
Originally Posted by EBMCS03' date='Dec 15 2004, 01:35 AM
[quote name='Guest' date='Dec 14 2004, 02:24 PM']Hey my digit number 8 is a 5 which is not listed!
[snapback]69219[/snapback]
[/quote]
OK Guys my VIN is WBANB33545B088830
The car was built on October 8, 2004, and is equipped with the rear side airbag option. In following the build of the car, I saw numbers all over the place, and not in any logical sequence, so when you figure out a way to decipher this, I will be interested. :'(
2005 545i(SMG)Sport,Black Saphire,Black,Anthricite,Comfort,Logic7,NAV,Sirius (Dealer Added),Rear Airbags,Cold,Fold Down Rear Seats,Shades
Kasmo
06-27-2024 06:02 AM
Stormcrow
12-01-2019 02:09 AM
Stranger12
Lounge
05-21-2015 12:47 PM
Sammie973
Bluetooth & Cell Phone Forum
03-12-2015 06:51 PM
ZeZe
10-15-2003 12:58 PM
Quick Reply: Modifications to e60 in 2005
