MASK Vs CCC
From what I've read in the forum, there are two different versions of the On-Board Computer (OBC). I believe that there is one called MASK and another called CCC.
Many posts suggest that the CCC is required for Nav Pro.
We also know that cars with Advanced Air Con, get a more advanced (OBC) with some additional functions such as speed warning and trip computer - are these functions of the CCC?
The UK options list states that Advanced Air Conditioning is a pre-req for Nav Pro - is this because the advanced computer (CCC?) comes with Advanced A/C?
Can anyone explain?
Thanks,
Phil.
Can anyone explain?
Thanks,
Phil.
i don't have proNav or Adv AC
but i do have speed limit alarm (thankfully turned off)
and
extended trip computer
so that doesn't make sense
where, please, in the UK specs does it say AdvAC isrequired for ProNav - ?
and
For the US anyway, it seems from the plethora of reading I've done, that you get the CCC if you order Nav and MASK without Nav. I seriously doubt that it's the same thing as the OBC or that the OBC is part of MASK or CCC functionality, but I'm truly clueless whether that's the case or not.
Sam
Sam
Skidster, do you have Business Nav?, if so, this would explain why you have these functions.
Sam, I think you're right, the CCC does not appear to be related to the std OBC functions.
That said, there does appear to be two different versions of the OBC, at least in Europe.
The following thread by jmcaiado provides excellent info on the CCC:
http://e60.doit.wisc.edu/forums/inde...showtopic=1722
What is it about Advanced A/C that makes it a pre-req for Nav Pro?
Does this mean that owners without Advanced A/C can't upgrade to Nav Pro, even if they already have Business Nav?
Phil.
Phil.
My Ride: F02 LCI Individual
Model Year: 2013
Originally Posted by tdocz' date='Jul 15 2004, 01:18 AM
SO, WHAT IS MASK?
WHAT IS CCC?
WHAT IS CCC?
MASK = multimedia audio system controller
jcolley
08-01-2016 06:48 AM
Bank$hot530
09-16-2015 01:28 PM
