maintenance question
Old Jun 20, 2010 | 10:38 AM
fredfifty's Avatar
My Ride: 04 545i Sport Package Straight Stock 89 5.0 Ford Mustang LX Coupe 06 R1 05 Zuma Scooter 09 Custom X "Titan" Bodyboard
so my brake fluid and microfilter "maintenance needed" indicator just came on...i just got this e60 used with 89k miles...it now has 90,700 miles...are these DIY or dealer recommended, and approximately how much am i lookin at from the dealer to repair these? thanks alot fellas
FF
Old Jun 20, 2010 | 10:41 AM
rctmthouse's Avatar
both are DIY, at least the microfilter is a definite and if you're not comfortable doing the brake maintenance, take it to an indy shop. No point to get rip off by the dealer.
Old Jun 20, 2010 | 10:51 AM
stoic1's Avatar
My Ride: '04 545i, sport pkg, premium sound, sprint booster,
The cabin microfilter is really simple. https://5series.net/forums/topic/831...__cabin+filter . You can go to You Tube and there is a DIY there also.
Like what was said in the above post, brake fluid is also a DIY just more equipment is needed.
+1 on using an independent shop.
Old Jun 20, 2010 | 12:28 PM
fredfifty's Avatar
cool thanks!
Old Jun 20, 2010 | 01:17 PM
fredfifty's Avatar
oh how do u reset the idrive so that it doesnt say maintenance is needed??
Old Jun 20, 2010 | 02:04 PM
SilberGrauE60's Avatar
Forum search is your friend as far as resetting iDrive service reminders.
Also, I went the indy shop route for my first brake fluid service not covered by maintenance plan, and they forgot to check the fluid level in the reservoir before beginning. Resulted in air getting in the lines when the reservoir went empty. The service took three times longer than promised (I waited) as they bled and re-bled the lines to get the air out. I believe there is still air in the lines, since the brakes seem spongy compared to before the service. I am not saying that the dealer would not make the same mistake, but I certainly lost confidence in this indy shop. And the only $$$ I saved between indy and dealer was the $100 for the scope that the dealer does.
Old Jun 20, 2010 | 09:38 PM
rctmthouse's Avatar
you indy shop guy didn't read the DIY instruction posted here before they did the work...always go to a reputable indy shop with experience on BMW. Yelp helps alot when it comes to searching for a good indy shop or you can as here or the the other forum.
Old Jun 21, 2010 | 06:24 AM
theXman's Avatar
My Ride: 2004 530i
Link to Reset Instruction:
https://5series.net/forums/topic/771...9&#entry880549
Old Jun 21, 2010 | 08:30 AM
fredfifty's Avatar
thanks Xman!!
BMW565
Nov 6, 2017 06:03 PM
ST JAMES
Jul 3, 2015 07:04 PM
star69me
Jun 17, 2015 07:40 PM
windnsea
May 25, 2015 09:49 PM
brian1225
Apr 16, 2004 05:59 AM
