Lamp blewout
[font="'Comic Sans MS"]Are these specs actually written on the bulb though? I've recently noticed there's a colour difference between my left and right xenon bulbs, and was wondering if I would be able to find out the colour temperatures by reading the label on the bulbs (it's an effort to remove because you have to remove the whole headlight assembly, so I thought I'd try and find out here first, before diving in...)[/font]
If you plan to replace a bulb, do the two bulbs (L+R) at the same time, otherwise there will always be a diference in color.
Regarding price:
I called a dealership service center and they quoted around $250 for 1 bulb.
I found some on the web for $55 which are identical.?.? http://www.oembulbs.com/osram-xenarc-66040-d2s.html
Although, the headlight comes on for about 30 seconds and then turns off. The service center advised to switch the bulb with the working bulb to ensure its a bulb burnout problem. It could be that the ignition module is causing the issue.
My Ride: 2008 550I,Space Grey,Hud,Cold Weather,M - Sport, matched GP Thunder headlights and Fogs,,Smoked Badges, Night Vision, Heated Seats,Rear Sunshades, Aux Audio, SAT, NAV, Black Grills, Sprint Booster, Dinan Cold Air, Stage 2 Dinan Software.....More to come soon
Switch the working bulb with none working to rule out "ignition module" malfunction. Then as suggested, replace both bulbs so the life cycle as well as color temperature match!
Agreed. But do you think the website bulbs are the same? Why is the BMW service center charging $200+ per bulb? :thumbsdown:
