Just Bought 545 - Huge Mistake?
Old Feb 12, 2010 | 07:14 AM
  #61
miguex's Avatar
From: Calgary, AB - Canada / Buenos Aires - Argentina
My Ride: 2006 BMW M5
Originally Posted by danzanchy
I don't think you made a mistake buying a 545 i love mine and i don't have warranty.. i ran into a few problems when i first bought the car, like 1200 dollars worth, but it now runs flawlessly, and has for the last 3 months... just stay away from the dealers cuz they like to make you think you have a problem with your car... either that, or they actually do cause problems with your car
wow, thanks for the links! hopefully i never need to use them but am going to save them if the day should ever come
yes, the problem will happen if you drive aggressively very often and the engine is getting very hot specially in hot weather. Obviously that ring will broke (BMW is aware of this). I think the 545i needs a bigger or better radiator to cool the coolant or bigger oil cooler (I think 545i can use the OEM or aftermarket M5 cooler). I wanted to do this but not very mandatory because Canada has long cold climate in a year.. so not sure... but maybe yes for hot climates such Ca, Tx, Fl, etc... I don't know...
Old Feb 12, 2010 | 07:16 AM
  #62
miguex's Avatar
Originally Posted by Iceman
The problem with that is, you still have to pay 1600 $ for a broken o-ring which is worth 1.50$
So I still have to say, buying a BMW V8 is a HUGE mistake if you want to keep it longer than the first four to five years of its life.
I will definately never ever buy one again!
Even the new F10 v8?
Old Feb 12, 2010 | 08:09 AM
  #63
jprovence's Avatar
Dude, you have clearly made your point it was a mistake to buy a V8 BMW. I would never own a BMW that didn't have a V8. Hell, I don't think I could own any car that didn't have a V8. But can you please keep your fear mongering to a minuium? Thanks.
To the OP... enjoy your car all that you can. If you are in the least be mechanically inclined, you can fix a majority of problems yourself. I have had a few things go wrong, but they have all been really enexpensive. One job was $6.25 to repair and took about an hour mostly looking for tools.
Old Feb 12, 2010 | 08:51 AM
  #64
Iceman's Avatar
My Ride: F02 LCI Individual
Model Year: 2013
DUDE,
I am only trying to let everyone know that having or buying one of those V8 engines is a huge mistake.
Isn't a forum exactly for that, discussing and gaining experience?
Again: Buyer beware!
Especially when you know how you get treated by BMW!!!
Old Feb 12, 2010 | 09:13 AM
  #65
rafichicago's Avatar
My Ride: 2008 BMW 550i M Sport
Trust me You will change Your mind when something serious will happen to Your car. Everyone have the right to post it's own opinion here. Trust me You CAN'T fix MAJORITY problems by Yourself. For most stuff You need to run diagnostics and Yes this is the electronics that F**** our cars up the most. What will You be able to do with a set of wrenches and screwdriver then? My 545 after 54K miles is in the shop for engine replacement. Will I buy a BMW again? I probably will. Did that destroyed BMW reputation as having strong engines? BIG TIME.
Old Feb 12, 2010 | 10:08 AM
  #66
devhan's Avatar
Although BMW has had V8s way back in the past the companies philosophy has been built around the flat two, four and straight 6 motors. Porsche flat 6s are their specialty but when they went to water cooling everything changed for them
When I went to the dealer to test diver various BMWs I really wanted to walk out of there with a V8 but decided against it remembering the bad times my friend had trying to fix the radiator amongst other things.
Old Feb 12, 2010 | 03:17 PM
  #67
Aviator's Avatar
My Ride: It's an E60 545I 6 speed.
Well now I'm offically worried, lol.
Old Feb 12, 2010 | 03:33 PM
  #68
EV4530's Avatar
Originally Posted by jdcinc21
I have an 2004 545i with 38,000. I bought my car from a person that never drove it either.
First thing you need to do is go to a NTB and get your engine flushed, bc you never know how long it sat!
And your only going to read problems people have with there E60 on here. The reason for this is bc the person with
the problem is lost and needs help. Thats what we do here, we help each other with problems with our cars and problems
with the stealership. Welcome and enjoy! Here are my before and after pics for a pick me up.
Beautiful
Old Feb 12, 2010 | 04:24 PM
  #69
Aviator's Avatar
I wonder if there are some types of antifreeze that have better lubricants for seals like that o ring. Or, if in fact these o rings are going out on cars that aren't getting the coolant changed as often as they should. Come to think of it, I have yet to flush/change the coolant in my car, and I've had it for a year now. I wonder if this issue will drastically devalue the already swiftly depreciating 545?
Old Feb 12, 2010 | 04:44 PM
  #70
jprovence's Avatar
You just had a freak accident. Its not like these engines are dropping like flys everyday. I have rebuild OHC engines before. Set timing chains for the cams. These cars don't run on magic. They are more mechanical then we get them credit for. It is not a big deal to pay a $75 fee for the dealer to diagnose the car, I fix it, then they program if needed for those electronic module. The only thing that really worries me on these cars are the transmissions. But the 545i transmission is in literaly millions of cars on the road. Everything from Audis to Land Rovers to the Hyundie Genises and even a Kia SUV. I have experience with hydrualic systems and repair. It would be nothing to take apart a component figure out what seals o-rings and who made them, find a supplier to rebuild. Do you thing your active sway bar needs to be reprogrammed because it leaks? No, it has zero electrical connections. Its a mechanical peice. Unbolt the old one, bolt in the new $1500 sway bar. I will be doing the valve cover gasket soon. All you have to do is unbolt the engine mounts and jack up one side of the engine on the oil pan lip( as per BMW dealer mechaninc) and things go much smoother.
Did you ever find out why your engine failed?
