Idrive Screen went blank
My Ride: 550i Manual Sport
Engine: 4.8 L N62 V8
All was well until the iDrive screen went blank yesturday on my way home from work. No Audio, Communication, Navigation, or Climate control menu. I pulled the following fault codes below:
Instrument cluster:
Instrument cluster / Kombiinstrument
Fault: Terminal shutdown
Code: A559
Fault: Debug Info Combi
Code: A557
Fault: Phone failure
Code: A554
Central info display / Zentrales Display
Fault: Central control timeout
Code: A468
Fault: CID failure
Code: A46D
Fault: Communication CAN Low
Code: E5C4
Do i have to replace the whole unit? Please help... very frustrated
Instrument cluster:
Code: A559
Code: A557
Code: A554
Code: A468
Fault: CID failure
Code: A46D
Code: E5C4
![Angry](https://5series.net/forums/images/smilies/imported/angry.gif)
There are numerous threads about this on the different forums.
- My I-drive went blank and started draining my battery from its cooling fan continuously running so I disconnected the I-drive completely.
- You can buy a used CCC (i-drive)
- You can buy a remanufactured unit
- Replace the faulty drive
- Upgrade to a newer model version
I'm solving other problems at the moment but have it on my list to either upgrade or replace the faulty drive. I'm not going to a buy a remanufactured CCC just so it can fail again in the near future. I'm no expert on this and I'm assuming you have a CCC not a CIC or newer I-drive version.
ccc or cic?
My Ride: E60 530d
If there is actually a can comms fault, the idrive won't switch on.
Undo the screen (two screws), undo the power connector and measure for Voltage there. (There's 4 wires, you've got to figure out which one is correct).
Also undo the first aid kit in the trunk and read the schematic for fuses
I give up, car is going in the shop. 550i is a great car but the CCC iDrive really sucks.. annoyed..
Problem solved... There was a quarter dangling inside CCC unit!!! Apparently, someone (my 2 year old son) put a quarter into the DVD slot. Its been in there for a while. I must of took a sharp turn which made the coin short out the unit internally. The coin was removed, everything is back to normal. And here i was talking bad about a flaky BMW CCC unit!!
Moral of the story, do not leave any coins in your coin tray if you have a 2 year old!!! All this money and time spent just for a quarter!!
LOL...
Reminds me of a VCR we had about 25 years ago. Thing stopped working. Took it to a technician where I worked that did VCR repair on the side. He gave it back to me a couple days later along with a couple of large-ish flash cards. My kid had stuff them inside the unit and somehow it took a tape in anyway, but got munged up.
Bank$hot530
09-16-2015 01:28 PM
