HUD is angled on glass
Old Oct 22, 2005 | 04:54 AM
  #21
cobradav's Avatar
Originally Posted by Rudy' date='Oct 21 2005, 09:57 PM
In TIS, the instructions are exactly the same as the E60...
[snapback]187186[/snapback]
Thanks, Rudy. I had assumed as much since so much was same or similar in Parts list. One thing I could not find in parts list for either E60 or E63 was the tilt mechanism and crank shown in the TIS, so it gave a little pause for concern. Another E63 owner was told that the E63 could not be adjusted and I wanted to help him out. Thanks again.
Old Oct 22, 2005 | 06:09 AM
  #22
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
I think the tools needed aren't in the regular parts system. They're part of the "special tools" that are available to dealerships and service centers. It's probably possible to order them but it's probably not worth it since this adjustment isn't likely to be something you'd do often...
Old Oct 22, 2005 | 09:09 AM
  #23
cobradav's Avatar
Originally Posted by Rudy' date='Oct 22 2005, 10:09 AM
I think the tools needed aren't in the regular parts system.? They're part of the "special tools" that are available to dealerships and service centers.? It's probably possible to order them but it's probably not worth it since this adjustment isn't likely to be something you'd do often...
[snapback]187275[/snapback]
From the TIS on adjustion skew/tilt it looked as though that was built in stuff behind the iDrive screen. Possibly not though, as they may not want DIY.
Old Apr 11, 2014 | 04:58 AM
  #24
ericyli's Avatar
My Ride: 520d
Hi Rudy,
The document made reference to a Lopsided HUD issue, and this is the exact problem I have. The image is displaced up-side-down. Would you know how to resolve this or where may I find a solution? Thanks, Eric
2008 520D
Old Apr 11, 2014 | 01:33 PM
  #25
twh's Avatar
twh
My Ride: 2006 BMW 530xi 6MT
Engine: N52
Is it completely upside down?
Old Apr 11, 2014 | 02:38 PM
  #26
ericyli's Avatar
My Ride: 520d
Yes, the entire screen completely up side down.
As if someone rotated it by 180 degrees.
Old Apr 12, 2014 | 09:41 AM
  #27
twh's Avatar
twh
Engine: N52
There are some older posts by Rudy about HUD with attachments. Have you looked at those? Could be that adjustment cable behind the iDive screen came loose?? That seems to have something to do with adjusting the HUD. I wouldn't think it can make it go 180 degrees, but it might be worth taking out the iDrive screen and inspecting that adjustment cable.
Old Apr 12, 2014 | 12:57 PM
  #28
ericyli's Avatar
My Ride: 520d
I have tried Rudy's method and adjusted the soft shaft behind the iDrive screen. It only move the screen little bit but no way near enough to correct the 180 degree rotation.
I have also tried to reset the iDrive (power, eject, and eject).
And resetting the iDrive using the 5 digital VIN addition method.
Took it to an auto electrician and he connect a diagnostic kit to the OBD and the reading was a connection error with the HUD. It was able to read the rest of the car ok.
Finally, in Rudy's document. It made reference to the lopsided HUD issue but said it will be described separately. So I guess BMW must have came across this problem previously.
cheers, Eric
Old Apr 12, 2014 | 06:31 PM
  #29
twh's Avatar
twh
Engine: N52
I haven't looked at the construction of the HUD, but a couple of Physics things come to mind.
Could the upside down image be a reflection of the real image which is mis-projected somewhere else? Think of a lake with a reflection of the surroundings. Could the real image be getting projected somewhere really high, for example, and you are seeing the upside down reflection of that?
Another thing could be some internal optical component that has fallen away. Like in old style cameras.
Old Apr 14, 2014 | 12:44 AM
  #30
ericyli's Avatar
My Ride: 520d
the BMW service book recognises this problem but said the solution will be described separately. I can't seem to find it and it's killing me. It's so close and yet so far.
alexbaldy
Sep 28, 2015 12:28 PM
DetailersDomain
Detailing Forum
Sep 22, 2015 03:59 PM
DetailersDomain
Detailing Forum
Aug 5, 2015 05:17 PM
shervinj
Jul 28, 2015 01:43 PM
CVTBenhogan
Jul 13, 2015 06:46 AM
