Hong Kong E60 sub-Forum
My Ride: BMW E60 530i , Silver with leather Air Con iDrive 17" Breyton Rims with Dunlop Sp Sport tyres (M-Tech Bodykit and rims WANTED)
Alfa Romeo 147 TS1.6 , Black with Air Con 17" Multi Spoke alloys with Bridgestone RE040 tyres
Toyota MR-S 1.8 VVTI , Lagoon Blue with Red leather Air Con 15" standard alloys with Toyo tyres
Toyota Celica 1.8 VVTI, Lagoon Blue, Air Con, 16" Standard alloys with Kuhmo KU31, EBC Green Stuff
same yr as my e90. fairly sure 525 in hk should be a 2.5 w the 3 stage manifold. the easiest way to check is your vehicle registration, which shows the engine size of your car. note that the power gain in this mod comes from the 3 stage manifold, the ecu flash is required to provide the necessary control (believe to resonate w the engine revs). in other words, if you have the 3 stage manifold, you must have the ecu flash already too. note that 2.5L w/o the 3 stage manifold only has 16x bhp. if you are interested to find out more yourself, can check in realoem.com using your vin # and compare part #s of the manifold from other e60 models, or alternatively can get somebody to do the work for you.
good luck!
good luck!
My Ride: 525i
good luck!
good luck!
i thought it is the same n52 engine for us/canada,
now, really don't know if it can make it the same as 530 after mod as the guy mention.
ya, i will check the realoem to compare the parts later. thanks alot.
i hope i can do, but not sure.
My Ride: Mini Cooper
my should be the same as yoursbut with more power
http://en.wikipedia.org/wiki/BMW_engines#Straight-6
http://en.wikipedia.org/wiki/BMW_N52
My Ride: '08 530i Luxury LCI
mine is a 2.5 for sure. do u mean mine already with the 3 stage manifold? if yes, then i don't need anymore mod?
Try stiffer anti-roll bar, it would transform your car's handling which is more direct and more enjoyable.
he what more POWER
