Hong Kong E60 sub-Forum
Old 06-01-2010, 04:47 PM
  #24601
billhk's Avatar
My Ride: carbonized MB coupe
if it was supposed to fit the stock, then easy peasy, just take it back for one that fits, i mean
is it TUV(type approved) or purpose made or as i asked "universal"?
actually the connecting pipe of the Arqray is exactly the same shape and bend as oem, just the muffler is different.
if you are driving on smooth roads that is fine, imagine going over a nasty bump........
KC- i don't think it will mess the manifold up, but there will be a dent in the exhaust very soon, then he can wrap
some exhaust wrap around that part to stop the rattle against the stiff bar.....
or get a softer exhaust hang rubber, that way it hangs lower.
Alan it is very bad having a rattle in a German car, you have the options, go for it.
Originally Posted by kcleung
the way I look at it, the vibration frm the exhaust touching the bar will be transmitted to the other parts connected it so the cat, exhaust manifold will have some additional stress. whether that will cause any actual damage in the short or long term, i wouldnt know. if you want to keep the bars, I would do what song bill suggested.
Old 06-01-2010, 05:20 PM
  #24602
pinguhk's Avatar
My Ride: Mini Cooper
mike , the exiga has your name written all over it
http://carscoop.blog...er-minivan.html
and go for the 430
they sell this in HK?
like bill say Subaru in hk :thumbsdown:
Old 06-01-2010, 05:23 PM
  #24603
kcleung's Avatar
Yes, saw it onlocal paper a few days ago. Am sure water good company can help even if it isn't
Old 06-01-2010, 05:28 PM
  #24604
kcleung's Avatar
It's certainly not Toyota or Honda but it will be fun. It has the flat 4 boxer engine and that's music to the ears.
  #24605
pinguhk's Avatar
Originally Posted by newbie2
David
I have installed the bars. I found that the rear and the middle bars also touch the pipes!!!
This is the rear bar
[attachment=135210:01062010177.jpg]
This is the middle
[attachment=135211:01062010181.jpg]
you will need to change the rubber that holds the exhausts to racing 1s which stiffer so the exhausts would not move and hit it.
BMW rubber are very soft and short
I did not install these rubber at AK, I did it at rainbow
I got the rubbers at MK 3 for $55
take a look at number 9.
http://forums.5serie...5&#entry1179735
Attached Thumbnails Hong Kong E60 sub-Forum-post-7188-127486632841_thumb.jpg   Hong Kong E60 sub-Forum-post-7188-127486633562_thumb.jpg   Hong Kong E60 sub-Forum-post-7188-127486637994_thumb.jpg
Old 06-01-2010, 05:30 PM
  #24606
pinguhk's Avatar
Originally Posted by mark_hk
I hear REFUND....
that ok can refund if you what.
Old 06-01-2010, 05:31 PM
  #24607
pinguhk's Avatar
Originally Posted by billhk
but it was also on Capt's car, didn't he post a photo of bending his exhaust to fit the bars?
maybe you can try to bend the bar? try with Wilson or Rainbow to do it.
is it a UNIVERSAL fit item?
yes that right I did say need to be custom fit, not every car is the same.
Old 06-01-2010, 05:33 PM
  #24608
pinguhk's Avatar
denting is easy, you just hit it with an iron bar...hard
bending is done by Mandrel, leaving no wrinkles inside the exhaust pipe
Alan, i think you had better take it off or you will have rattles and more trouble,
maybe Capt can think of a solution.
but i heard from KC that the improvement in control was excellent!!!
yes rainbow can bend the pips.
they could have bend my 1 to fit, but he say it be better making a u channel to be safe.
Old 06-01-2010, 05:34 PM
  #24609
pinguhk's Avatar
thought it didnt fit on Capt car cos he has aftermarket exhaust but was meant to fit for cars with stock exhaust???
It dose fit need to change the rubbers
Attached Thumbnails Hong Kong E60 sub-Forum-post-7188-127486633562_thumb.jpg
Old 06-01-2010, 05:37 PM
  #24610
kcleung's Avatar
It's just a theory of mine. U probably r right and might be it will be ok. Just since Alan asked for worst case scenario...
Quick Reply: Hong Kong E60 sub-Forum
