Help I have an issue
Old May 25, 2007 | 07:11 PM
KU530's Avatar
Someone help my trunk will not close. I had notice the last few weeks that I had to slam the trunk pretty hard to get it to close now it will not close at all. It seems like there is something in the way but there is not. crawled in the trunk and tried to shut it so that I can see what was blockin it but I could not find anything. And don't worry my back seat is currently out of the car so I would not get stuck in there. Anyone have any insight on this?
Old May 25, 2007 | 07:36 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
If you press the little release switch (above the license plate) do you hear any noise? If it's working properly, you should hear a little motorized servo or solenoid sound. If you don't hear anything, the switch may be stuck.
Sometimes the rubber gasket that surrounds the switch can become dislodged and force the switch to stay in the "release" position. Get a good look at the entire area up under there and make sure it looks like things are flush and sealed.
If that isn't the issue, double check that the release handle in the trunk is properly seated (the handle you are supposed to use to open the trunk if you end up getting carjacked or accidentally locked in the trunk.)
Old May 25, 2007 | 07:47 PM
KU530's Avatar
Rudy it does make the noise and the handle is seated. from inside the trunk the latch does not come and meet the striker.
Old May 25, 2007 | 08:00 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Hmmm. Without seeing it myself, it's hard to say what could be happening other than a mechanical misalignment of some sort.
Not sure how mechanically inclined you are -- if you are, see if the following documents shed any light on things. If not, tie it down and take it to the dealer, I guess (or maybe BMW roadside assistance?)
Adjusting rear lid lock (lower section of rear lid lock):
RA__Adjusting_rear_lid_lock__lower_section_of_rear_lid_lock_.pdf
Removing and installing rear lid lock (upper section):
Master_Removing_and_installing_rear_lid_lock__upper_section_.pdf
Old May 25, 2007 | 08:14 PM
KU530's Avatar
Attachment 32895
Attachment 32896
I am very mechanically inclined, I have wrenching on cars for a long time. I will give this a shot and see what I come up with.
Old May 25, 2007 | 08:17 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
DavaiLave
Aug 2, 2022 02:16 AM
indigof
May 21, 2015 10:31 AM
DennisM
May 20, 2015 12:12 AM
coreybunz
May 1, 2015 07:24 AM
