E60 for Singaporeans
#5391
Originally Posted by lmk' post='287867' date='May 26 2006, 11:24 AM
nuvi 300 is the european equivalent to US nuvi 350
Nuvi 310 is the equiv. to Nuvi 360 in USA
the main difference is the bluetooth built in Nuvi 310 and 360
Both models are firmware upgradeable and provide "text to speech""
i.e. turn right 100m ahead into Orchard road.
and not
"turn right 100m ahead at the junction.""
and not
I kinda like the TiBo's ability to view MP4.... how does the C320 and the new Nuvi fare in that dept?
#5392
My Ride: E39 525i, E60 530i, F10
Originally Posted by SFL33X' post='287848' date='May 26 2006, 10:58 AM
Hi, sorry for sounding confused.... Garmin uses the malsingmaps maps right? and it also has it own "off the shelf" map? So... I should get Garmin C320 cos the maps are free and more updated?
I went to Pin Liang this morning to see its VDO and Vit@s GPS.
I think if the Garmin doesn't come thru by tmr... I am gonna head down to Sin Ming to get the TiBo...![Blink](https://5series.net/forums/images/smilies/imported/blink.gif)
Pin Liang may not be the best place to buy a GPS, you probably know a lot more than them after spending some time in this forum.
![Happy](https://5series.net/forums/images/smilies/imported/happy.gif)
Not sure how often TiBo updates its maps but IMHO buying a GPS with good updated maps is important. You can either get a Garmin or Pocket PC running Garmin's free Que software that reads Malsingmaps for both Singapore and Malaysia.
#5393
Originally Posted by SFL33X' post='287874' date='May 26 2006, 11:32 AM
I see... so the key difference is still the lack of Bluetooth...which means it cannot use as a speaker phone for our HP...correct?
http://www.garmin.com/products/nuvi360/
where do you want MP4? if you install the v/interface, you can almost play all video files through your CID.
#5394
Originally Posted by lmk' post='287908' date='May 26 2006, 01:07 AM
take a look here
if i buy a nuvi here with out the US maps can the US maps be copied over or must buy from garmin..ie password protected???
#5395
Originally Posted by lmk' post='287908' date='May 26 2006, 02:07 PM
take a look here
Thanks lmk... btw, how do I install the v/interface?
#5396
Something I found on the net for the much touted SiRF III and WAAS... unfortunately this feature which you pay for...in the Garmin Nuvi 310/360 would not be useful outside North America....
WAAS
You've heard the term WAAS, seen it on packaging and ads for GARMIN products, maybe even know it stands for Wide Area Augmentation System. Okay, so what the heck is it? Basically, it's a system of satellites and ground stations that provide GPS signal corrections, giving you even better position accuracy. How much better? Try an average of up to five times better. A WAAS-capable receiver can give you a position accuracy of better than three meters, 95 percent of the time. And you don't have to purchase additional receiving equipment or pay service fees to utilize WAAS.
What is WAAS?
The Federal Aviation Administration (FAA) and the Department of Transportation are developing the WAAS program for use in precision flight approaches. Currently, GPS alone does not meet the FAA's navigation requirements for accuracy, integrity and availability. WAAS corrects for GPS signal errors caused by ionospheric disturbances, timing and satellite orbit errors and provides vital integrity information regarding the health of each GPS satellite. Although WAAS has not yet been approved for aviation, the system is available for civilian use, such as for boaters and recreational GPS users.
How it Works
WAAS consists of approximately 25 ground reference stations positioned across the United States that monitor GPS satellite data. Two master stations, located on either coast, collect data from the reference stations and create a GPS correction message. This correction accounts for GPS satellite orbit and clock drift plus signal delays caused by the atmosphere and ionosphere. The corrected differential message is then broadcast through one of two geostationary satellites, or satellites with a fixed position over the equator. The information is compatible with the basic GPS signal structure, which means any WAAS-enabled GPS receiver can read the signal.
Who benefits from WAAS?
Currently, WAAS satellite coverage is only available in North America. There are no ground reference stations in South America, so even though GPS users there can receive WAAS, the signal has not been corrected and thus would not improve the accuracy of their unit. For some users in the U.S., the position of the satellites over the equator makes it difficult to receive the signals when trees or mountains obstruct the view of the horizon. WAAS signal reception is ideal for open land and marine applications. WAAS provides extended coverage both inland and offshore compared to the land-based DGPS (differential GPS) system. Another benefit of WAAS is that it does not require additional receiving equipment while DGPS does.
Other governments are developing similar satellite-based differential systems. In Asia, it's the Japanese Multi-Functional Satellite Augmentation System (MSAS), while Europe has the Euro Geostationary Navigation Overlay Service (EGNOS). Eventually, GPS users around the world will have access to precise position data using these and other compatible systems.
![Nono](https://5series.net/forums/images/smilies/imported/nono.gif)
WAAS
What is WAAS?
How it Works
#5397
or you can ask him to arrange everything for you including wires and tv tuner.
he installed for most of us.
#5398
WAAS
You've heard the term WAAS, .......
WAAS
No doubt WAAS is not utilised outside USA but SirF III is useful here.
the 24 satelites at more than 60,000 ft above us are owned by the US forces.
They were used for military purposes but had since open to civilian use as the US forces are into more sophiscated equipment
therefore all the signals we received are free, if not, we need to pay subscriptions to use it.
For most of us, these signals is good enough for accuracies up to 25-50m.
As to SirF III chip, this is a new GPS chip that can receive up to 32 channels at one time. you need at least 3 sat to give accurate data. Try it, side by side, it will take longer for a non SirF chip to lock on to 3 sat before providing useful navigation. Accuracy from a SirF III receiver is more accurate anytime.
#5399
My Ride: Nothing to boast about!
Originally Posted by lmk' post='287933' date='May 26 2006, 02:22 AM
Too Chim liao.
I have vkool klar at the front, Sirf II couldn't even lock. With Sirf III the lock was in seconds for warm start.
#5400
Originally Posted by Stranger' post='287944' date='May 26 2006, 04:16 PM
I have used both Sirf III+ and Sirf II. I junked the latter which I had used only 1 time after I saw the former in operation.
