E60 for Singaporeans
#4831
Originally Posted by lmk' post='270422' date='Apr 18 2006, 10:21 AM
fortunately i am driving the lowest end of the range....mod bugs did not manage to attack me..hehe!
but of cos, i cannot say the same if i am heading for my next change...
#4832
Originally Posted by Stranger' post='270415' date='Apr 17 2006, 08:32 PM
Andrew posted a very useful writeup on the com0com stuff at
http://forum.bargainpda.com/showpost.php?p...8&postcount=147
But I don't think it works anymore. I will try a simple write up for you later when I have time, if you are interested.
yes im certainly interested but im absolutely hopeless following technical instructions only good at destruction..ha ha.
mods i have done so far to my 523i
ACS 18 TYPE 4 RIMS
PS2 245 40 18
ACS FRONT LIP
ACS EMBLEM
ACS SPRINGS
VOLTAGE STABILISER
AUX IN
TV TUNER
REVERSE CAMERA
MAC MINI
GPS MAP HOLUX MAPKING
BLUETOOTH
ARB
STOPTECH BRAKE LINES
WEIGHT REDUCTION
m5 mirrors
AND MY CAR IS ONLY 5MONTHS OLD...........EVIL OR NOT HA HA
TO BE CONTINUED........................HA HA
#4833
My Ride: Nothing to boast about!
Oh no! BZSAB, if you do all these, you will need the famous wing flaps for sure.
1628, ok I am too lazy;so I searched and found the original write up for you.
http://forum.brighthand.com/showpost.php?p...8&postcount=147
Good luck...
I would suggest you edit the file using a normal editor. The 2 com ports you use **must** be unused when you try to install. Note that these 2 com ports will not be registered properly with the OS. You might have them overriden by something else later on if you install other stuff that uses virtual com ports. I normally use 2 numbers that are far away from the highest com port in use.
Good luck...
#4835
Originally Posted by Edlee' post='270555' date='Apr 18 2006, 07:24 AM
1628, I'm thinking of the voltage stabalizer and grounding for my rides. Can you pls share if the stabalizer has helped in any way?
the voltage stabiliser has effect but i dont think it is that noticeble especially your car is dam powerful any way. would be good for older cars but i installed any way to improve current flow.
i know some one who installed two and swears by it.
#4836
Originally Posted by Zig' post='270085' date='Apr 17 2006, 03:18 PM
Do any brothers here know if PML will void my E60 warranty if I am to install a
1. Broquet Fuel Charger?
2. KN air filter or Hurricane air filter?
#4838
My Ride: E39 525i, E60 530i, F10
Originally Posted by tategoi' post='270581' date='Apr 18 2006, 10:31 PM
Well, I can only say "Mod don't scared, scared don't mod!"
#4839
Originally Posted by Zig' post='270596' date='Apr 18 2006, 10:58 PM
Well said! Let's mod mod mod!
