e60 aux input in the back
Old 05-26-2016, 07:18 PM
BostonJon's Avatar
My Ride: BMW 530xiT (E61)
Originally Posted by cmyachtie
instead hooked up a Bluetooth PC board receiver to stream music,
please elaborate on this setup
Old 05-30-2016, 02:50 AM
cmyachtie's Avatar
My Ride: 2004 545i+BT+AUX+Coding
Engine: N62
https://5series.net/forums/bluetooth...eaming-139872/
Plus various other like options, just try google
Old 03-20-2023, 03:37 PM
Dj530's Avatar
My Ride: 2006 530xi (One black & one grey) 2010 X5 535d 1974 BMW 3.0CS 2008 535i 2009 335d
You can follow the suggestion by cmyachtie and just make a couple changes. I purchased a bluetooth module like the one below.
I had previously upgraded to the LCI USB/AUX located in the center console and I didn't want to change that.
I simply took the bluetooth module and installed it behind the radio. (Made the mistake of hooking it to constant power so I could listen to radio/bluetooth without the key. Bluetooth didn't like that, it needs to cycle on/off, otherwise you can't connect to it.)
Next step was coding to make Aux 2 functional. Everyone knows that you can add AUX if you didn't have it, but you can add multiple AUX'S.
As you can see, I have 2 Aux inputs. I also have CD, CD Changer, and can run the DVD player from the 7series on the Most network (sold that player). While I was in the center console I pulled out that phone holder/storage tray. It was to small for any of my phones. . . . . .
More space, much better than before.
Old 03-20-2023, 04:46 PM
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
@Dj530 You can add more AUX's to the iDrive with what process?
Old 03-20-2023, 07:09 PM
Dj530's Avatar
I used NCS EXPERT to make the changes. I will take a look tomorrow for the items you need to change. I may even have backed up the changes, so I could forward you the file.
Old 03-22-2023, 07:17 AM
Dj530's Avatar
Okay, once you load NCS EXPERT, open the module list and click on CAPPL. Open it with NCS DUMMY. Search for MM_DEVICE - EXTERNAL MULTIMEDIA DEVICE and change it to Aktiv.
In the above picture you can see the AUX input is AKtiv along with the MM_DEVICE option. The Aux 2 is interfaced on the rear or the head unit.
stevieT
03-14-2023 01:56 AM
Tyler Knighton
05-19-2014 07:55 AM
///M-Power
09-27-2011 03:31 PM
CHAN1855
01-23-2006 03:27 PM
stream
09-27-2005 08:44 AM
Quick Reply: e60 aux input in the back
