Crank no start
My Ride: 05 530i m tech 6 speed
no the battery wasn’t registered because the car won’t start to take it to the dealership to get it registered. It’s the same exact battery, same size, cca and amp hours. And no I don’t have inpa, I tried downloading it 2 years back and had no luck getting it to run
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Do you know how to unplug the IBS cable from the negative terminal. If so unplug it just to make sure it's not an IBS issue. To do it you take the negative terminal off then unplug the plug and bolt the negative cable back on to the battery.
or_550i
03-04-2011 02:45 PM
