Boot wont open
My Ride: Bmw 5series E60 530i
530i boot wont unlock either by the latch fob or key. Back seats are fixed so can't access to open from inside. Any advice please? Thanks
Yes, the button on the boot is what I meant by the latch. How to solve the issue is the problem as can't access via the back seats. They are fixed and don't move whatsoever
When pressing the unlock button on fob all other doors open ok except the boot, the boot open button won't open it either or manually with the key in boot lock
Are you sure you're turning the manual key far enough? You should be able to go counter clockwise between the 9 and 10 o'clock position. It may take extra effort if the actuator is jamming the latch.
I have a 2008 528i. Had the same problem, turned out I needed to turn the metal key a bit further, like donpb said it requires extra effort. I finally got it open but then the latch would not engage to close it. In trying to close it repeatedly I messed up the latch. Took it to dealership and they told me a couple wires were broken as well as the latch. In all, they charged me $850 for the repair.
When my trunk latch would not engage, I disconnected the wiring loom in order to keep my trunk closed. I located three broken wires that I decided to fix myself.
coolguy
06-02-2007 12:47 PM
