Bmw e60 locking problems
hello, I have 530d 2003, sometimes my car lock, but sometimes I need to manually. Mostly it unlocks in cold weather.
All 3 keys have this problem
I checked fuses
I checked fuses
Administrator
My Ride: 530xi
Engine: N52
I find the electronics in our cars (and in all cars really) act funny in extremely cold weather. How do they work in normal temperatures?
My Ride: 2005 545i, premium package, 6sp manual, cold package, navigation package.
Model Year: 2005
Engine: N62
My Ride: E60 523i MSport
Model Year: 2005
Engine: N52B25
I have had similar problems with my 05 e60. When I first bought the car only one key worked if I had it very close to where the antenna sits(top right corner of rear window on sedan, above rear window in the middle on estate). The other key didnt work at all. My local bmw specialist did a diagnosis test and found that the keys worked like they should but it was most likely the antenna, they replaced this one and then everything worked fine, I could unlock the car from far away. But now lately only one key works, and it varies how close to the antenna I will have to be, I think it depends a little on the temperature like said earlier in this thread. My local bmw mechanic tested the keys and found that both batteries were bad.
When all 3 of your keys have this issue I would think that the antenna needs replacement, since its very random that all keys should fail at the same time. Do you have bmw shops nearby? They most likely have a key range tester. Either they find keys are good and they need to replace antenna or something else, or the keys are bad and need new batteries. You will have to be able to solder in order to replace the batteries, and batteries can be found cheap online.
Hope you find a cheap solution!
rob187
Sep 3, 2021 06:59 AM
BemveE60
May 2, 2017 10:50 PM
zakizzy
Dec 26, 2014 06:11 PM
Heloha
May 30, 2008 07:19 AM
