Anyone notice these things....
#21
Banned
Originally Posted by rodybmw' date='Jun 10 2005, 01:38 AM
[quote name='BMW530' date='Jun 9 2005, 03:43 PM']
You are correct.? When the high beams are one (PUSH position) the Xenon high beam is on and the inner halogen high beams come on too.? Double the brightness?
[snapback]138027[/snapback]
OK.....so there is a slight difference between the US and Euro versions. When I PUSH on the lever in my car only the Xenon high beams come on, but the halogen (inner high beams) stay off. The halogen inner high beams only come on when the lever is pulled.
[snapback]138168[/snapback]
[/quote]In the US, the halogen inner lights are also the DRLs. The reason the inner lights are used for flash-to-pass is that xenon lamps take several seconds to heat up and fully illuminate, so they're useless for flashing during the day.
#22
My Ride: 535d Sport in Carbon Black / high gloss shadow line and beige leather / dark poplar with professional nav, bluetooth phone prep, CD changer, bi-xenon adaptive headlamps, servotronic steering, folding mirrors, heated comfort seats, TV, extended voice control and Logic 7 hifi.
Originally Posted by JMB' date='Jun 10 2005, 08:43 AM
Right! this is the way it works in Spain. Flashing with xenon lights is forbidden because it's dangerous for other drivers, so carmakers disable this function and install halogen bulbs too for flashing.
#23
My Ride: G30 M550i
Model Year: 2018
Originally Posted by clived' date='Jun 10 2005, 10:05 AM
If the feature (flashing the headlamp by pulling on the stalk) is disabled, why do they install the bulbs?
[snapback]138216[/snapback]
#24
Originally Posted by clived' date='Jun 10 2005, 08:05 AM
[quote name='JMB' date='Jun 10 2005, 08:43 AM']Right! this is the way it works in Spain. Flashing with xenon lights is forbidden because it's dangerous for other drivers, so carmakers disable this function and install halogen bulbs too for flashing.
[/quote]Flashing the headlamp by pulling the stalk is NOT disabled....Here's a summary of how it works:
<span style='font-size:14pt;line-height:100%'>US E60's:</span>
PULL....inner halogen high beams ON.
PUSH....outer xenon high beams ON, inner halogen high beams OFF.
<span style='font-size:14pt;line-height:100%'>European E60's:</span>
PUSH....BOTH the outer xenon high beams AND inner halogen high beams ON. (according to some European members here).
As someone already said flahing with the xenons is not used because if the headlights were off (in daytime) it would take a few seconds for the xenons to go to full brightness and do the auto level adjust. When flashing is used usually there is no time to wait for that to happen, so the inner halogens are used instead. Either way they can't leave out one of the bulbs as you said because both the xenons and halogens are used at one time or another.
#25
My Ride: F02 LCI Individual
Model Year: 2013
If the car has xenon lights, auto-leveling and washing is also mandatory by law, for the same reason.
This is probably true for all EU countries.
[snapback]138169[/snapback]
#26
[/quote]Sorry, perhaps it's my bad english...
Flashing is forbidden with xenon, not with halogen. This is the reason why they install halogens for flashing (and, yes, they work together with xenons when you push the stalk for high beam)
umnitza
09-02-2015 11:28 AM
spediegunz
08-30-2015 09:43 AM
