Alternator bracket gasket question..... Some advice please!
My Ride: 04' 545, 6 Spd Manual, Blk Lthr, Sport Pkg, Sport Sts, Logic 7, Cold Wthr Pkg, Full L.E.D. Interior, Red Eng. Cvr, Mtech Front Bmpr, M5 Spoiler, Matte Blk Grill, Red Caps, Slttd & Drlld Rotors, 20
I was doing some snooping under my hood and found a good amount of oil on the under carriage cover (topside). Spot is on the alternator side directly below it. I'm assuming it is the alternator bracket gasket that has gone bad. Funny thing is though i check the oil and the level seems to be good (fortunate to have a dipstick) Anything else on that side of the engine? I called my mechanic he says the job will be somewhere around 1k if it turns out that's what it is. For anyone who's done this or familiar with the repair do you think this is reasonable I just want to know. I'm pissed I have to pay so much for a repair and the part is less the $2. Shit is crazy.
My Ride: 2006 550i
I did the same repair recently on my 2006 550i. It's not overly difficult or complicated but it will take some patience. If you're handy in the garage then it's not something you should fear because you're simply unbolting things and putting them back on. Problem is you need to remove about a dozen parts just to get to the damn bracket.
Removal of radiator/fan covers, removal of electric fan, serpentine belt, belt tensioner, power steering pump (set mine to the side so as not to disconnect hoses), alternator, oil cooler hoses (if equiped), driver side wheel, plastic inner wheel well, and motor mount...then you can remove the bracket to change the $1.50 gasket. A couple of these items I removed just to get a little more room since everything is crammed into such a tight spot. Another thing to note is that many of the bolts are tough to reach and you may need a couple of specialty sockets like external torx for the motor mount bolts.
Not too technically difficult but time consuming...hence the 1k for your mechanic to do the job.
My Ride: 545i
Its pretty easy, just time consuming. As for the TIS, do a search. I posted a link to a new one. You just have to have google translate it from Russian to English. And tools, a socket set with torx bits, a breaker bar, and most important an E-torx set. The e-torx are inverted torx bits. You'll need them to remove the engine mount and alt bracket. Don't use standard sockets on the E-torx. You'll strip them. When you put in the new gasket use a bit of sealant as well. Just added protection.
My Ride: 545i
You can do it in a weekend. Yes all of that has to be removed. Have a look at this thread. Details about the bracket gasket. https://5series.net/forums/diy-do-yo...i-545i-120107/
I notice the exact same looking leak on my undercarriage cover but, luckily for me I traced my leak back to my vacuum pump. Fixed it last week and no more leaks since. My ac compressor and the surrounding area was covered in oil and so too was my whole front undercarriage cover.
I'd suggest you remove the cover (6 screws) and take a look. The area under my alt was clean as a whistle. You'll notice right away if it's the dreaded alternator bracket leak or not. Good luck
