Advanced Air Con....stooopid question
on adv. air con there are independent controls for temperature for both driver and passenger.
when you have the system in "Auto distribution mode" i.e when the the symbol on the bottom corner of the iDrive screen shows the two letter A's. is it OK to set the temperature on just one of the dials? or will the system still give different temperatures on either side of the car if the dials are set pointing to different values i'e one points to 18 the other points to 22.
