Adaptive Headlight System INPA error... please decipher!
Old 12-12-2015, 09:31 AM
  #31
BraveHelios's Avatar
My Ride: 2004 545 6 M/T
It's fixed... I think! At last!
I replaced the AHL module part number 61 35 6 934 837 and the flashing green LED is gone!
It's been so long though, I forget what exactly is normal operation. What it does now:
1. Rotate the switch counter (anti) clockwise and green LED comes on... steady green LED.
2. Rotate the switch clockwise and no green LED comes on at all.
3. The part I put in had a p/n of: 61 35 6 934 837. The p/n I removed is: 6 934 122. Does one supersede the other. Which one supersedes which?
Also, can someone tell me why I can pull and extend the headlight switch from its housing? I still have full functionality but can't figure out why I can do this... what is it designed to do?
Old 12-12-2015, 02:54 PM
  #32
jtbgonesailing's Avatar
My Ride: e60 530i e21 320i
Model Year: 2005 1981
Engine: M54 M10
Take a look in: realoem.com
Old 12-12-2015, 03:24 PM
  #33
Been there. A bit confusing as to which one superseded the other.
I did notice that in auto mode, the green light (and head lights) go out in the day light and come on in the dark (or in the garage).
I think that if anyone else is dealing with this issue, they may want to go directly to this module. I bought a second hand module and it worked right away... no programming needed.
I am glad I reinsulated the head light wires while I had them out trying to figure this thing out.
Old 12-14-2015, 08:25 AM
  #34
To be perfectly clear on this...
If anyone happens to get the error code:
E-519 LM No Message (road speed, 1A0)
The very first thing I would do:
Check your headlight housing wiring to make sure the wiring insulation is not crumbling. If it is; fix it!
When the wiring insulation is fixed; then:
Replace the AHL module part number 61 35 6 934 837.
Fixing these two items restored my AHL.
Good luck!
Greenewolfe (01-26-2021)
Old 12-15-2015, 05:47 PM
  #35
cmyachtie's Avatar
My Ride: 2004 545i+BT+AUX+Coding
Engine: N62
Control unit, adaptive head light
From:02/24/2003To:12/20/2005 (ENDED)Weight:0.070 kgPrice:$184.44
Superseded by:
61356934837 (08/31/2004 — ) , Exchangeable retrospectively
This should explain...copied from realoem
Old 12-16-2015, 06:04 PM
  #36
Notheld's Avatar
My Ride: BMW E60
Engine: E60 M54
Thumbs up for the info and fix!
jfmartin25
11-02-2022 01:42 AM
TexaZ3
05-06-2015 09:54 AM
kurtb23
04-22-2015 04:30 PM
08-12-2003 11:41 AM
Quick Reply: Adaptive Headlight System INPA error... please decipher!
