Adaptive Headlight System INPA error... please decipher!
2 Attachment(s)
2004 E60 545i with 6sp manual.
AHL system just started malfunctioning... blinking green LED by headlamp switch. This occurred slightly before the alternator failed (hence the 11.79 volts); but I have since replaced the alternator; all errors are gone except for the AHL. FWIW... I also replaced the fog lamps with 80 watter halogens just before the green light blinking and the alternator fail. I ran INPA and came up with the attached errors. With this information, can anyone tell what part of the system failed?light1.PNGlight2.PNG Thanks! |
Am I asking in the wrong forum? Anybody?
I don't know what everyone else is seeing, but when I click on those thumbnails I get tiny pictures with text so small it is completely illegible.
try posting again with bigger pictures of that screen shot. |
Can't read the pics either. However, it could be a problem with the stepper motors or the aiming system. Pull up to the garage or anywhere you can see the lights, put the headlight switch on auto turn off the car then turn it on. If the lights don't auto level then something is wrong with the system. If it still levels then use winkfp to reset the ahl modules.
Originally Posted by Gee_115
(Post 1527645)
Dude, I am sorry, but that is a silly thing to do. Why would you put in a 80w bulb in there? Not only will it start melting/bubbling the chrome plating on the reflector, it is potentially a fire hazard since the stock wiring was never meant for that measured current. Take that shit out before it cause some damage.
As for your issue, yes, your pics are too tiny to see. If it's not doing vertical self test, it most likely is a motor issue, so SOL, need new headlight. |
That makes sense. I will do that asap. Do you think the incorrect bulbs in the fog lights caused the motor to fail?
Originally Posted by nomis_nehc
(Post 1528082)
As for your issue, yes, your pics are too tiny to see. If it's not doing vertical self test, it most likely is a motor issue, so SOL, need new headlight. Also; you mentioned headlight... each headlight has a motor; correct? I would have to figure out which headlight motor failed. Any ideas here would really be appreciated! |
(Post 1528082)
(Post 1528088)
Not necessarily, the AHL control modules can fail. There are two AHL modules, one for each headlight. They are located under the bottom of the headlight. I would try replacing those with used ones, you can find used ones for $40-$60. You should also try to print the INPA readout to a pdf then attach it here so we can actually see the error. There is a program called PDFLite you can use that or just do print to file.
Something is causing your stepper control modules to malfunction. Friend just recently had this and had to get one of them replaced, you have to see which one the code is coming from. If they arent giving a code check your FOOT-WELL MODULE, it may be malfunctioning. Also happened to my friend. You should be able to see for INPA if its throwing a code. since your alternator was bad it may have caused it the short out, or your 80w bulbs may have done the same. Those are the only things i can say to check since this happened to my friend and he had all these replaced. |
