550i fuel filter part number?
My Ride: E60 550i
Model Year: 08
Have you tried looking it up on RealOEM.com - Select Your BMW Model?
Is it supposed to be on driver's side underbody area?
Updating after further check, is it inside the tank ??
https://www.realoem.com/bmw/enUS/sho...diagId=16_0554
If that is the case it appears complicated and not really clear if it is required to replace.
My Ride: 2006 BMW 530xi 6MT
Engine: N52
Could not find it, maybe I'm missing something.
My Ride: 2008 550i 6-spd; 2007 530i Sport
It's not under the car, it's under the backseat.
It's been a while since I did this but I seem to recall "unscrewing" the metal ring about a quarter turn, lifting up the existing filter, disconnecting a couple hoses, removing it, then reconnecting the hoses to the new unit and dropping it bank into the tank , then securing the metal ring with a quarter turn to seal in place. It's important that you get a good seal with the rubber ring/gasket to ensure no leaking.
DB_Gutz
Aug 31, 2023 09:47 AM
