535D with error codes (INPA) - What is the car telling me?
Old Oct 29, 2013 | 01:57 AM
JayCartay's Avatar
My Ride: 535d M-Sport
Default 535D with error codes (INPA) - What is the car telling me?
Hi guys,
I got my hands on INPA, NCSExpert and all that stuff this weekend, and this morning I finally managed to get to reading the error memory on the car. My cheap OBD II reader had told me that the car had error P3263, but nobody seems to know a definitive root cause of that code.
So, with that in mind, I bought a cable with the INPA software.
I have managed to track down the meaning of the codes, and they are as follows:
4212 Glow Plug Cyl 1 - Activation Interrupted
4232 Glow Plug Cyl 3 - Activation Interrupted
4262 Glow Plug Cyl 6 - Activation Interrupted
4252 Glow Plug Cyl 5 - Activation Interrupted
41F2 Electric Ventilator - Activation Interrupted OR 41F2 Electric fan, activation
3FF0 Air Flow Meter OR 3FF0 Air-mass flow sensor
3EED Power Management Closed Circuit Current
5F15 Brake block wear rear axle
A0B0 Brake light
A0B0 Brake light
9EC0 Heating driver failed
9EC1 Seat ventilation supply, cushion and seat back
9CC3 Battery exhausted
A468 External open circuit (LVDS data line)
Now the battery I knew about, as I flattened it one day by leaving my ODB II reader plugged in
Brake light codes I presume are referencing when the bulbs have gone at some point and the dealer I bought the car from said it needed brake pads before I bought it, so that covers the brake block wear codes.
Unfortunately I have no clue on the others. I didn't think my comfort seats were ventilated, and they certainly both heat up when the heating is turned on, so not sure there's an error still present on these.
The engine stuff is what's bothering me the most. Do I need any replacement parts according to these codes?
I've now cleared the codes and will check over the next couple of days for any of them coming back, but the P3263 that I found via the OBD II reader did come back after a few days the last time I cleared it.
If it helps, I also got this information:
E R R O R M E M O R Y
Date: 29.10.2013 08:16:25
ECU: D60M57D0
JobStatus: OKAY
Variant: D60M57D0
RESULT: 4 error in error memory !
4212 4212 Glow plug zylinder 1, Control
Error counter: 1
Logistic counter: 40
Mileage 147096 km
Engine speed 0.00 1/min
coolant temperature 11.97 °C
Rail pressure Actual 0.00 bar
Injection quantity 39.38 mg/Hub
Air mass per cylinder 0.00 mg/Hub
Charge pressure Actualwert 1033.84 mbar
Pedal value sensor 0.00 %
Battery Voltage 11730.69 mV
Vehicle speed 0.00 km/h
Status of glow display 0.00 -
Unterbrechung Test conditions fulfilled
Error present now, but not yet stored (debouncing phase)
Error would not cause a warning lamp to light up
Fehler in Entprellphase
Error code: 42 12 44 02 00 00 01 28 47 D3 00 3E 00 64 00 69
00 48 00 00
The same values are reported for cylinders 1, 3, 5 and 6.
Many thanks for any help.
shoryuken15
Apr 9, 2015 03:42 PM
Stranger12
Apr 5, 2015 10:42 AM
wrx5
Mar 29, 2015 04:53 PM
mishka69
Mar 20, 2015 03:32 PM
Margal
Mar 9, 2015 04:45 PM
