2nd gear grinds
Banned
My Ride: A Car
lately, the mornings are freakin freezing. Every morning, my car HAS to grind going from 1st to 2nd but only does it one time. I've had that in the past with my EVO and it was pretty normal. Just lightly slip into second anf third will ok. Has anyone experienced this with their e60?
My Ride: 05 545/6
every V8 BMW I've owned does this. i've had transmissions replaced only to get the same behaviour. sometimes I get 2nd, others i just keep going straight to 3rd. usually goes away by second stop. and "cold" for me is never less than 60degF. at this point I just live with it. if you're out of warranty, switching to royal purple synchromax helps a little.
it is much better in my e60 than it was in my e39, but then again, my car only has 24k miles right now. i imagine it will get worse as the miles pile on.
you try letting the car warm up for like a min before going? i use to gwt that with my mazda 626 when i would change from 1st to econd. but in our cars your dont have to wait but just give it a min to warm up next time and see what happens =)
My Ride: 2005 530d
I've had this just recently in the cold snap, never had it before.
Also just happens once then never again.
SO many problems recently, i feel like changing car but wont due to the current climate
My Ride: 2006 530i Sport
Silver Gray - Black Leather - Anthracite Maple
Manual Transmission
Premium Audio
Cold Weather Package
Rear sunshade
Sirius Radio
Autobahnd Roadblock (3M) film kit
Never had it happen. Does it matter how fast you shift?
What happens if you double clutch?
My Ride: 2008 535i 6MT
My stock E60 1-2 shifts in the cold are notchy but no grinding. This was the same in my E90. Did you remove the CDV, install a SB, or clutch stop? Also make sure you are completely depressing the clutch.
My Ride: 2004 BMW 545i Sport Package, Titanium Gray II Metallic, Wheel Style 124
Banned
My Ride: A Car
I had a similar griding sound that I would hear from the rear at low speeds ... Turned out it was my rear disferential ... Dealer replaced it, just the part it self was 2k glad warranty pick up the cost ... After that car drove quiet and more power from what I feel
My Ride: 05 545/6
bestofthebest
03-28-2016 02:47 PM
bestofthebest
01-05-2016 07:47 PM
