2004 545i still rough idle
#21
I did some more reading and will replace my fuel filter next. I overlooked that and it is a lower cost approach. I will post it when I complete the job. Thanks again fellas.
#24
My Ride: 545i
#25
Still following thread. Having idle vibration still as well. Hopefully we can try a few things and come up with a solution for all. Mine happened after installing new spark plugs. Attempted a few sets since without any change. Most recent changed fuel filter sender assembly. No change except a little more performance.
#26
My Ride: 545i
Found this Looks like i Finally discovered BMW V8 secret!!! - Bimmerfest - BMW Forums. Its 7 series related but same n62 motor. Might not be cause of bouncing idle but is interesting.
#27
Just coming in on the tail end and haven't read all posts, so excuse me if this SB has already been discussed.
My 2004 545i was doing a lot of idle rpm hunting, dipping below 500rpm and almost dying before recovering. I suggested this SB to my Indie. He instead used some injector cleaner and that seemed to correct the problem.
However, I have kept it in the back of my mind for the future.
#28
My Ride: 2004 545i Sport
1998 M3
However, I have kept it in the back of my mine for the future.
#29
Not sure if it helps but I chased a similar issue with my 545i. I replaced my maf sensor all vacuum hoses and lines, finally cleaned my vanos solenoids and it cleared for up for a day or so. It ended up I had slightly overfilled my oil at my last oil change and it was messing up the vanos. It was barely over the full mark on the dipstick.
#30
Overfilling the crank case can turn catastrophic quickly as the splashing crank drives air into the oil in the sump, changing your oil into a frothy mess that has almost zero lubricating ability. Journal bearing and ring failure doesn't take long.
