17x7.5 --> 17x8 Offset Question
Old Jan 8, 2011 | 04:58 AM
evets's Avatar
Will this change the offset on an xi model from 43mm to?
I believe moving from an 18x8 to an 18x8.5 takes it from 43 to 40, does it also apply on a smaller wheel?
To ask another way, will a 535xi wheel go directly to a 530xi without issue provided it is correct offset from the beginning on the 535xi?
Thanks in advance
Old Jan 8, 2011 | 05:08 AM
08white's Avatar
My Ride: 2008 BMW 535XI white
i believe oem bmw wheels for xi is 17x7.5 with 43 offset, but style 277 and 278 for 2010 xi is 17x8 with same offset
so if you go from 17x7.5 to 17x8, 43 offset is ok, but if you go aftermarket wheels, i will do little lower offset, like 40 or 38, that way wheels can line up with fender little more
Old Jan 8, 2011 | 06:20 AM
luigi524td's Avatar
My 530xi 18x8.5 CSL reps have a 35mm offset ... that moves them out about 1/4 inch compared to the stock 18" wheels. IMHO Barely noticeable.
BurtonSnol3order
Jul 3, 2015 09:28 PM
ST JAMES
Jul 3, 2015 07:04 PM
star69me
Jun 17, 2015 07:40 PM
windnsea
May 25, 2015 09:49 PM
brian1225
Apr 16, 2004 05:59 AM
