suspension noise when cold
Old Jan 7, 2011 | 05:23 PM
rouge's Avatar
I am experiencing suspension noise when the temperture is below freezing. The noise occurs when going over speed bumps or railroad tracks. Seems to be front and rear at different times.The noise resembles a crunching sound. Any ideas??
Old Jan 7, 2011 | 06:34 PM
NoQuarter's Avatar
Engine: N54
You need new sway bar bushings if you want the noise to stay away. Or you can wait until it warms up, the noise will go away, and you will still need new sway bar bushings but not know it until other symptoms.
-Jim
Old Jan 8, 2011 | 04:36 AM
rouge's Avatar
Thanks!
Old Jan 8, 2011 | 06:25 AM
luigi524td's Avatar
Definitely sounds like suspension bushings ... cold weather brings out the worst in rubber and plastic parts. You might try to buy time and quiet things down a bit by spraying joints and bushings with WD-40 or Silicone/Rubber lubricant.
TopPMP
Aug 10, 2020 04:15 PM
Ejceles
Aug 13, 2015 04:42 PM
srogers535x
Aug 5, 2015 08:48 AM
e60fans
Jul 27, 2015 04:52 AM
ripley
DIY: Do It Yourself
Jul 12, 2015 01:49 PM
