Upgrade to Business Nav, advise needed
Hi all ! This is my first post and i wish to first thank whoever is running this forum as this is a mine of information !!!
My Xmas gift this year was special : A Business Nav kit bought on Ebay by my Father in law ;-)
My car is a E61 11/2004 530D that comes with a CD player only.
Here are some pictures of the kit :
I am wondering if these two parts and the DVD are enough for a Retrofit.
Is there a guide on how to replace the idrive ?
Some details of the DVD player
651913982710252497
344759
MT1 80
MT2 68
MT3 52
EK 02
SYS 57
652171521004a or q
bmw e60-m-ask
65.12-6 955 347
hs 652147695959
ai : 01 e 8e98.s 41/2004
6521j1047695959
On the Idrive
accession 00r0271
hw 12
ec 145
651913982710252497
344759
MT1 80
MT2 68
MT3 52
EK 02
SYS 57
652171521004a or q
bmw e60-m-ask
65.12-6 955 347
hs 652147695959
6521j1047695959
On the Idrive
accession 00r0271
hw 12
ec 145
My Ride: BMW e60 525IA 12/2003
Hi mmarco50
Nice present to get , nice father in law to have
Well okay , shall we take the best part first , you wont have to change the I-Drive controller , thats only nessecery when you upgrade to Nav. Prof.
The "bad" news is you will have to change the "shark fin" antenna to one with GPS if it should be done 100% according to BMW norm , but the easy way is to buy a simple standard GPS antenna and mount that under the roof or in the upper corner of the windscreen , you will properly have to alter the connection for the antenna wire to fit ther connector on the M-ASK ( radio unit ).
A coding of the car to the "new" Business M-ASK will properly be nessecery , depending what option's your car have now , and witch the car it came from had , if you are lucky it's the same . elsway you will have to go by the BMW dealership afterwards for coding.
Good lock with the project , and let us know how it goes.
Best Regards
BenAnd
Best Regards
BenAnd
Originally Posted by mmarco50' post='776234' date='Jan 24 2009, 06:41 PM
Thank you very much BenAnd !!! I feel much more confident now knowing I won't have to change the I drive !!!
I noticed that the slot I want to replace with the DVD is not the same dimension : See picture
Attachment 70285
Do I have to buy a new plastic that would fit ?
Attachment 70285
The trim is the same for all M-ASK ( Business M-ASK or regular M-ASK ) , first with the LCI model there is a difference.
Originally Posted by BenAnd' post='776261' date='Jan 24 2009, 02:30 PM
Hi mmarco50
But if you look at the pics the business Satnav i want to fit is too small compared to the Cd charger that is already fitted. There will be a gap.
I did not fin any topic about fitting business satnav in place of the CD player, most are about upgrading to pro satnav and in this case the trim comes alraedy with 2 slots, one with DVD and on with CD player.
Do I need then to get a special extra bit of trim ?
What you are trying to compare is the M-ASK already mounted in the car "sitting" behind the trim , and a M-ASK with out the front-trim on , so when you take off the front-trim in the car , you will see that the radio M-ASK look's the same , so no reason to worry , it will fix it self , when you get to the point of mounting your new Business nav N-ASK.
chadillac2000
42
09-13-2017 11:15 AM
tom333
04-01-2015 01:56 PM
