Tapping in for signal
Hey, do any of you guys know if the signal coming out of the factory headunit is processed before or after it reaches the factory amp? on a standard us spec system.
Before. Amp is just used to boost the signal for the subs.
My Ride: E46 330, E60 550 on order: Carbon Black/Natural Brown, 6MT.
Originally Posted by Motors4fun' post='448558' date='Jul 16 2007, 07:15 PM
Does this mean you can tap into those wires and put RCA ends on them and usa a cable to connect that to the amp? I am trying to not use a line level converter if possible.
I think they use a balanced setup, which is logical in an electrically noisy environment like a car.
My E39 had a balanced set up but people we tapping into them. I did it aswell. The trick was to use an amp that can handle an input signal greater then 6 volts i think.
Does any one have a complete pinout of of the amp in the trunk?
thanks again
thanks again
thanks again
thanks again
umnitza
09-02-2015 11:28 AM
spediegunz
08-30-2015 09:43 AM
