Sirius Satellite Module Install (DIY)
#61
My Ride: 2007 525i 6 spd ... [IMG]http://i970.photobucket.com/albums/ae188/shebuilt/e60/DriverSide1.jpg[/IMG]
Hoping to revive. Original owner removed unit. Going to buy one to replace. Can I simply plug it up and it recognize satellite signal? I do notice the SAT option is not in my iDrive and I do not have NAV.
#63
I do have it according to VIN and again I see where he removed unit and I can see the wiring. Once I get the replacement unit and I plug it in, what next? Thanks so much.
#64
Well now I was premature! Found the instructions. Boy do I hope there are ways around taking it the stealership!
#65
My Ride: '05 530i
Shebuilt........if you're still around. Sorry to resurrect an old thread, but I'd like to plug and play a new Sirius module as mine just went. We're you able to plug and play, or did you need coding?
#67
My Ride: 2008 528i Black on Black
#69
My Ride: 2008 BMW M5
Hi there, I have a M5 2008 e60 with pre wired, i just install the module tuner xm only two plugs antenna and the power cable and fiber optic. do i need to mess with the fiber optic or go straight to the dealer and let them code the iDrive so i could see the SAT.
