Removing the swirl flaps in a diesel engine
#242
Hi all - my first post here.
Recently bought a 530d 2004 80k miles.
Did all the reading on the common faults, swirl flaps, breathers, thermostats EGR etc.
Must admit to being a little anxious about the swirl flaps in particular.
Anyway did the flaps job today and the EGR stat while I was at it. Not too bad a job, if you have a good set of tools to hand.
Finally pulled the inlet manifold, got it on the bench and had a good look.
F***** ME!
5 flaps working ok, but 1 had lost one of the fixings screws.
It was twisted and didn't operate with the rest.
As it was jammed against the side, it wasn't possible to pull the whole flap out of the manifold.
I reached in with a finger to see if it would rotate and the bloody thing fell off.
The shaft sheared just where the second screw was. No force applied at all.
Seems the car has ingested one screw in the past and got away with it.
It was only a gnats fart from taking the whole flap in.
With all the crud that accumulates in the manifold, it's easy to see at a glance these flaps are no
Where near strong enough in construction.
A run after the job showed there is no noticeable difference pulling away
as everyone else seems to report.
If you are even thinking about checking the flaps on your motor, DO IT NOW!
Don't bother with blanking plates - why waste money? It's not like you are likely to ever see them again.
A 6mm self tapper screw will wind in nicely where you remove the shaft from the existing plugs. They will screw into the plastic nicely and seal perfectly. Add a blob of araldite to the head of the screw for further peace of mind.
I have shivers just thinking how close this was...............
F***** ME!
#244
My Ride: 535D Tourer - Pre LCI
I'd like to say a massive thank you to the OP for this thread.... I did this today after printing off the guide - I couldn't have done it without this thread.
The only problem I had was the lack of a Dremel or similar tool
, thinking a hack saw would do the trick. I found the hack saw very very labouring after finding that I had the strengthened flaps, so in the end i chopped the plastic body with the saw and took off the plastic head to allow the flaps to fall out.....
Much respect!!
Tim
![Worthy](https://5series.net/forums/images/smilies/imported/worthy.gif)
Much respect!!
Tim
#245
Just about to attempt this tomorrow weather permitting, just been to a DIY shop and the guy is confused at the size i said about the M5 screws, he reckons there's no such thing as a M5 screw just m5 Threaded bolts which have a nut on them are called M5, the screws in the picture are called self tappers over here in the uk and come in size 2/4/6 then 8?.....not sure which ones to get tbh?
#249
My Ride: 2006 525d M-sport,19" staggered style 95 wheels,custom quad exhaust with modified reiger rear bumper insert,LCI front and rear lights,stage 2 custom remap, DPF removed, cat removed
Great write up mate!
Is this only a problem on the 3.0 engine? Or is it all 6 cylinder diesels?
