Remove Trunk Lining Question
My Ride: '05 545 Jet Black, Miro 111's, Painted Calipers, Slotted and Drilled Rotors, Ultimate Interior LED Kit, ACS Rear Spoilers (reps), HID 7k Fogs, Black Roundels and Badges, 20% Tint, Mtech V2 Angel Eyes, Ksport Coilovers, M5 Bumpers and Side Skits, ACS Front Lip (rep), and probably more on the way as you read this...
If I remove the trunk lining in the trunk door, will I be able to see the prongs from the rear roundel? I was removing my trunk roundel and both prongs broke off, so I don't know how to remove them. Right now they are stuck in the gaskets with no room to grip, so I can't figure out any way to get them out other than going in through the back and pushing them out. So I guess my questions are:
1. Can I get to the inside of the prongs by taking off the trunk liner?
2. If so, how do I remove the trunk liner? It appears to be held on by flat black plastic heads, but they don't have slots for a screw driver. Maybe they're clips, but I need someone tell me how they come off so I don't break them.
3. If I can't get to the back of the prongs from inside the trunk, how do I go about removing them?
Thanks.
Thanks.
i drilled them out.
socale39
Sep 5, 2023 08:30 AM
