Rear window anti-trap reset
Old 09-09-2009, 06:43 PM
  #51
e60hodzic530's Avatar
My Ride: 550
I just tried it and it worked thanks alot
i started my car
went to the rear left door and opened it
i clicked and held the button to open it ( it opened 3 inches) and kept holding it for 20 seconds and then quickly closed it and held it for 20 seconds...the way you know it works is because as youre holding the close button your window begins to open all in one complete motion and than closes in one complete motion as well..thanks alot Rudy
Old 09-14-2009, 12:23 PM
  #52
mobilejo's Avatar
My Ride: 535d M Sport - Visibilty, Media, Logic7, Heated Comfort Seats, too many other extras to list
Another post just to add that I followed Doug's instructions to the letter and it worked perfectly.
Thanks.
Old 09-17-2009, 10:59 AM
  #53
offalis's Avatar
Post
After nearly chopping off my daughters finger I had to fix the anti trap!!!!!
Glad to say yes 17 secs does the trick, had to download a stopwatch for my Nokia E51 to get it bang on.
Well Done Posters
Offalis
Old 09-19-2009, 05:14 PM
  #54
chikhodra1's Avatar
Post
it was truly correct. i had to try 3-4 times but finally got it. thanks million guys!!!!!!!!!!!!!!!!!!!
Old 12-12-2009, 12:34 PM
  #55
DJKR's Avatar
Cheers Doug et al! 17 Seconds worked a charm!
Old 01-14-2010, 05:27 PM
  #56
CodeTitan's Avatar
My Ride: [B]2010 BMW 528i[/B] - [SIZE="1"][I]Space Gray Metallic, Gray Dakota Leather, ZPP, ZVP, Navigation, iPod Adapter, Heated Front Seats, Fold Down Rear Seats[/I][/SIZE]
Wow! I am so glad you posted these instructions. I tried a bunch of other techniques that I found via Google and this was the only one that worked. Thanks!!
Old 01-21-2010, 04:36 PM
  #57
1997540i's Avatar
Originally Posted by Doug0403' post='618509' date='Jul 7 2008, 10:29 PM
Worked like a charm for me on the second try.
I did not hear any beeps, I did accept the inital warning that comes on when you start the car, and go into service codes to see the actual "anti-trap" error when I performed it for the second try.
Also I believe you CANNOT sit at the driver side to perform these unless the driver side window is the one with the issue.
Here were my steps...
1) I had the car started
2) Roll down the window all the way from the "broken" window (it wants to stop every xx inches, keep making it go down all the way)
3) I released the switch
4) I pushed and held down (I heard from another place that it needs to be exactly 17 seconds)
5) After 17 seconds I immediatly pulled up on the switch to roll the window up (it went all the way up).
6) after the window went all the way up, and still holding the up switch, it rolled all the way down, and then all the way up once more.
7) After #6 the process was complete and the window was functioning normal again.
Hope that helps.
I have a 1997 540i and the One-touch function on my front driver's side window hasn't worked in quite some time. I've tried this process several times (holding the button down for exactly 17 seconds) without any success. I'm wondering if there is a different process because I have an E39 rather than the newer E60. Any ideas?
Old 04-06-2010, 04:30 PM
  #58
gbaty0001's Avatar
My Ride: 2004 530i Black/ Smoked LED side markers/ CF kidney Grille/ Shadowline Trim/Miro 346 V2/General Exclaim 19"/CF Badges/H&R Sport Springs/ Koni FSD shocks/struts/R1 Concepts Drilled & Slotted Rotors/ Hawk Pads/ Mtec V2 lights/
17 second trick does the trick!!!!!!
Old 06-03-2010, 10:15 PM
  #59
problemchild1one's Avatar
My Ride: ' 05 545i 6 on the Floor
OK, I'm having a problem with my front passenger window..."power window anti trap function" and i tried the 20 hold down i read from another thread and now my window is stuck up and does not want to roll down and i did it from the passenger window can somebody please help
Old 07-04-2010, 07:15 AM
  #60
KrisH's Avatar
Thanks guys, google pointed me in this direction, 17 seconds did the trick for me!
Quick Reply: Rear window anti-trap reset
