NCSExpert Code Mods
Old 06-04-2012, 02:07 PM
  #591
hollow's Avatar
i know this has already been done : enabling oil level in idrive ,but people with diesel cars found that it doesnt work ,assuming the diesel doesnt have the level sensor . well while draining the oil i noticed that the diesel does have this sensor i even removed it to check it was correct . anyone know of any reason why it shouldnt work when coded ? all diesels cant have a busted sensor
Old 06-06-2012, 03:48 AM
  #592
adi_fox07's Avatar
Hello guys
it is any way to have welcome home light on my e60 with LM1?
My car have the latest software version.
Old 06-06-2012, 07:51 AM
  #593
stecom90's Avatar
Originally Posted by adi_fox07
Hello guys
Hi,
Impossible, you need LM2.
Old 06-06-2012, 10:16 AM
  #594
Soryn14's Avatar
My Ride: BMW e60 525Da LCI White, DPF out, Front grill black, Shadow line, license plate super bright led, interior white leds;
I code the car with 676$ and now i hear the subwoofer but verry worse. I search on this forum but i didn t find the code for hifi
Old 07-15-2012, 08:30 AM
  #595
robself705's Avatar
My Ride: 530xi
Hey guys I just did the Orion V2s in my headlights and removed the old angel eyes from my headlights and now (obviously) I have errors saying the bulbs are burnt out. I tried to search this thread and the forum as well as the spreadsheet and could not find which module and which functions I have to change to remove cold/warm checks and error messages. Has anyone done this or does someone know which functions to change? Also I heard some one mention even if you code the checks away you might still need a small resistor across the wires?
I really appreciate the help.
Old 07-15-2012, 05:30 PM
  #596
bymer's Avatar
Hello guys
Maybe you can't have Welcome Lights, but I enabled Follow me home lights by coding
(Activate AE, Xenons, Brows, Rears with a push of a button from the Key Fob.
in NCS LMA module > Change
HEIMLEUCHTEN_FUNKSCHL
aktiv
HEIMLEUCHTEN_KL58G
aktiv
Quick tap on the Trunk button will activate these.
Old 07-19-2012, 08:00 AM
  #597
skunkd's Avatar
My Ride: 04 530i 06 ///M5
Originally Posted by BlaSTiWi
Sorry not sure I'm on LM2 so maybe you can try make DRL_V_GEDIMMT function nicht_aktiv to turn off DRL on LM1.
this worked btw... Pre lci lm1 that had factory highbeam day time running lights. I changed this setting and the DRL's were disabled thanks.
Old 07-19-2012, 08:04 AM
  #598
skunkd's Avatar
Does anyone no the coding to get rid of the door gong while key is in ?
Old 07-24-2012, 11:23 AM
  #599
nunorsilva's Avatar
My Ride: BMW E61
Model Year: 2009
Engine: N47
Hi all.
I've done some coding on my 2009 E61 (thank you all for the great info provided on this topic) using NCS.
Although I've searched a lot (probably the problem is the correct word to search for) I have not found a solution for a simple (I think) coding: anybody knows what do I need to code so that when I start my car the ventilation is OFF?
I've tried some items on IHKA and MASK modules with no success.
Thank you.
Regards,
Nuno Silva
Portugal
Old 07-25-2012, 12:52 AM
  #600
stecom90's Avatar
Hello,
KOMBI:
CC_ZUENDSCHLUESSEL > aktiv
aktiv
HEIMLEUCHTEN_KL58G
aktiv
You know what are the other functions "HEIMLEUCHTEN"? :
LM1
Code:
DEF_HEIMLEUCHTEN_CKM
	wert_02
HEIMLEUCHTEN_VERLAENG
	nicht_aktiv
HEIMLEUCHTEN_ABBRUCH
	nicht_aktiv
HEIMLEUCHTEN_SEND_OPT
	wert_01
Quick Reply: NCSExpert Code Mods
