NCSExpert Code Mods
#441
... BEIKLAPPEN_B_KOMFORTSCHL is the function that will enable the mirror folding via key fob.
Are you sure you're looking inside the KGM module? Does it show up in the global?
#442
I've scanned this thread a few times... not sure if it's been fully answered yet or not:
I want that "ding!" chime gone. Totally gone.
I don't need a "ding!" telling me to put on my seatbelt.
I don't need a "ding!" telling me the key is in the ignition.
I don't need a "ding!" telling me my windshield washer fluid is low because I went trigger happy with the squirty thingy 5 minutes ago.
I don't need a "ding!", period.
Preferably, I'd like to do it through software. However... I haven't been able to find a single option (nor a big combination of options) that'd kill that "ding!" once and for all.
If my search for removing that via software fails, I'll probably just give up. By give up, I mean disconnect the speaker under the steering column.
#443
The ding! comes from the main speakers so you could disconnect those
#444
#445
#446
My Ride: 2006 525i Msport Professional
Gents,
G?Day and Thanks for a great resource.
I have coded a few things with success :-
VIDEO_DENY_COB
LEGAL_DISCL
MDrive
HUD_M
BC_DIGITAL_V
BC_DIGITAL_V_KORREKTUR
BC_V_KORREKTUR
M_SPORT_HUD
BLINKER_AUSSTATTUNG
GEBL_ANZEIGE_AUTO
I have a few things that are being stubborn :-
Panic Alarm - SONDERTASTE_PANIKALARM
Side Lights ? LED replacement KALTUEBERWACHUNG_SL_V_R
Alarm sound - ACOUSTIC
aktiv
C941C_QUITT_AKUST_KLAPPE: fkt_frei
K9416_QUITT_AKUST_ENTSCH: fkt_frei
C9413_QUITT_AKUST_SCHAERF: fkt_frei
I have found some functions appear in more that 1 module eg ACOUSTIC is found in In CAS, KOMBI and CAPPL.
Which unit should it be programmed in or changed in ? Should it be changed in a specific order eg CAS CAPPL then loaded into KOMBI ?
Any help greatly appreciated, Thanks
VIDEO_DENY_COB
LEGAL_DISCL
MDrive
HUD_M
BC_DIGITAL_V
BC_V_KORREKTUR
M_SPORT_HUD
BLINKER_AUSSTATTUNG
GEBL_ANZEIGE_AUTO
aktiv
#447
Since you want to avoid warning pop up due to using LED, in addition to cold check you might as well disable the hot check and also the warning function all together:
Code:
KALTUEBERWACHUNG_SL_V_L -> nicht_aktiv KALTUEBERWACHUNG_SL_V_R -> nicht_aktiv WARMUEBERWACHUNG_SL_V_L -> nicht_aktiv WARMUEBERWACHUNG_SL_V_R -> nicht_aktiv FEHLERMELDUNG_CC_SL_V_L -> nicht_aktiv FEHLERMELDUNG_CC_SL_V_R -> nicht_aktiv
#449
Model Year: 2010
Sunroof module MSHD. There is one function to enable sunroof switch operation when the ignition is off.
The sunroof switch still worked after the car alarm is armed and locked, even though the window switches are not working. I sat in the locked car with the motion sensor disabled. I could still operate the sunroof one, two and three minutes after ignition off. Not sure if that is a good thing.
HTML Code:
CHECK_IGNITIONC aktiv
#450
Can anyone confirm please - I have found in TIS that:-
Function National versions - Acoustic confirmation from siren when primed and disarmed US and Canada only
For the UK viewers can you confirm or deny that you have ACOUSTIC Alarm acknowledgment both visual and audible
(siren ?chirp?, signal lights flash), or only visual ?
This would explain why this programming doesent work
aktiv
aktiv
