Changing the orange LED to white LED on the cluster to look like M5 or
#251
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic,
Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release,
Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
Hi guys i removed my cluster only removed the needles to check one of the leds now the rev monitor needle is not moving any idea what could be wrong all the others work fine
#252
My Ride: ///M5 BEAST
hey, im curious if i can simply buy an E60 M5 cluster and plug & play it with my pre-LCI (Feb 04 build) 545i?
i am bidding on a couple clusters on ebay and im hoping that its a simple install...
does anyone know?
does anyone know?
#254
My Ride: 530i
Mods: M5 sporty package, M5 Steering wheel, Sprint Booster
Not plug and play, either need coding or swap the chip.
#255
My Ride: Mini Cooper
you will need to reprogramme the car and it might not work too.
#257
#258
hello do you still have some of these leds ? i tried to find some of them on ebay but i couldnt
what type exactly is ? i mean if it is smd, how many chips, voltage. could those fit ? http://cgi.ebay.com/20-pcs-SMD-SMT-PLCC-2-3528-1210-White-LED-Super-Bright-/190526324296?pt=LH_DefaultDomain_0&hash=item2c5c40fe48#ht_2936wt_1037
#259
Contact TheRacerBoss he has the best eyebrow solution/option on the planet. He just helped me with mine and now they are super bright white...visible in the daylight. I'm super happy with them!
#260
what type exactly is ? i mean if it is smd, how many chips, voltage. could those fit ? http://cgi.ebay.com/...#ht_2936wt_1037
