Car Coding
Old 03-24-2012, 04:13 PM
  #661
turboawd's Avatar
My Ride: 2006 BMW 550i
have you tried just to recode the module with out a man file? and then see if the option is there?
Old 03-25-2012, 04:41 AM
  #662
hollow's Avatar
yes i ended up doing that earlier today and the option is there . so now i have angel eyes active as drls . they do however seems duller than normal .
Old 03-25-2012, 01:29 PM
  #663
2010E60inMs's Avatar
My Ride: 2010 528i E60
Hey guys, I am new and just did my first coding today !! I want to thank you all who have posted info on the translations of lines and what they actually affect. It is fun and boy does it save so much time ! I will now start reading in prep to add/change the VA order.. Thanks again and I will let you guys know what I get done and ask for help if i need it !! I love this site !
Old 03-28-2012, 02:09 PM
  #664
AchtungE60's Avatar
My Ride: E60 530i
Originally Posted by Laurentiu79
My car is 530d from 12.2004
I believe your car comes with a dipstick no? Ffor your engine oil level there is two parts you need the physical part as well to monitor the oil. Just because you got something to show up the CID doesn't mean it will actually work. In the U.S. 2004/2005 models have dipsticks so i'm assuming you have one. Sorry if I'm incorrect.
  #665
AchtungE60's Avatar
My Ride: E60 530i
keep reading on, this has been discussed too many times.
Old 04-11-2012, 08:34 AM
  #666
pcy
pcy's Avatar
Hi,
Which ECU module has AUX (or AUXIN) located in?
I see that it's in the .TRC file after reading CAS. Then, when I go to individual ECUs, none of them has AUX parameter.
thanks in advance.
Old 04-12-2012, 08:26 AM
  #667
C_o_s_m_i_n's Avatar
CAPPL / Mask.
Old 04-12-2012, 09:42 AM
  #668
pcy
pcy's Avatar
Originally Posted by C_o_s_m_i_n
CAPPL / Mask.
CAPPL is not in the list of ECUs for my car ('06 530i with build date of March 2005).
LMA is there, I will try using that...
Old 04-18-2012, 01:37 PM
  #669
AchtungE60's Avatar
My Ride: E60 530i
It is not LMA this the light switch module. It's either M-ASK or CAPPL
And which AUX parameter are you trying to use/change? did you read about any of this first?
Old 05-07-2012, 03:46 AM
  #670
Then you must have M-ask. The LMA does NOT contain the information you need.
Quick Reply: Car Coding
