Car Coding
Old 02-16-2012, 10:40 PM
  #651
iamnatio's Avatar
Originally Posted by Bazz530i
I've probably got the same problem here, I have recieved my cable last week and coded the indicator's light in HUD and can read al sorts of modules, but I'm unable to read the LMA2 which I desperately want to code because I've got LED rear bulbs and want to mount HID in AE. With coding I would be able to stop the dimming of the AE.
Any idea how to find newer "daten" files?
I had to get v41 daten files for my E60 and I got them from here:
https://rapidshare.com/#!download|341l33|1075756066|E60_V41_Daten_Files.r ar|3155918|R~68168067FB716A2EF5BF80E634191B1C|0|0
Since it is over 3GB I had to sign up for the site in order to download that file.
Old 02-18-2012, 12:53 PM
  #652
0-60Motorsports's Avatar
My Ride: E46 M3 04
Awesome thread and DIY Bro! Thanks.
Old 03-02-2012, 09:29 PM
  #653
Bazz530i's Avatar
I managed to get V45 daten files, thanks to all great guys at this forum!!
Old 03-13-2012, 04:02 AM
  #654
Laurentiu79's Avatar
My Ride: E60 - 530d
Hello to all, I made ??some modifications in HUD - I activated turn signal and Mdrive. The signal is working, but the Mdrive work only for 10-20 second and after returns to the classic HUD. Another problem is that the red of the rpm counter is much higher than normal. The top button on the steering wheel you can not use and also in the iDrive mode i can not select the new MDrive button. (which appeared after installation).
MDrive
nicht_aktiv -> active
HUD_M
Control unit: HUD
M_SPORT_HUD
nicht_aktiv -> aktiv_handschalter
[Turn indicator in the HUD]
Control unit: HUD
BLINKER_AUSSTATTUNG
The last problem is the engne oil level - I installed this function, but I know how it works or not
I hope someone can help me, thanks
My car is 530d from 12.2004
Attached Thumbnails Car Coding-img_0510.jpg   Car Coding-img_0511.jpg   Car Coding-img_0512.jpg   Car Coding-img_0513.jpg   Car Coding-img_0514.jpg
Old 03-13-2012, 04:30 AM
  #655
NoQuarter's Avatar
Engine: N54
"The last problem is the engne oil level - I installed this function, but I know how it works or not"
what sort of engine oil function did you install? Was the car started when you tried to check the engine oil level?
The diamond button will not work with the Mdrive changes coded.
I have not read that anyone has calibrated the green/yellow/red bands on the RPM HUD display for a non-diesel E60. It can be done via NETTODAT coding.
See my miDrive thread (signature) for more info what I am doing to get back the use of the diamond button. I am turning it into an "M" type function to enable specific settings.
Old 03-13-2012, 04:50 AM
  #656
bruce_miranda's Avatar
I'd be interested to know a resolution to this Engine Oil issue. Ever since I retrofitted a CIC i have a menu that is supposed to be able to measure Engine Oil but I get the same error i.e. no measurement possible. However my car is a diesel, and I don't know if diesels were able to measure engine oil via the idrive or not.
Old 03-13-2012, 05:02 AM
  #657
My Ride: E60 - 530d
I don't know what function was install, an friend has did this.I tried the function with the engine cold and hot, and nothing.
What should I do to stay active M-mode?
Old 03-13-2012, 08:50 PM
  #658
turboawd's Avatar
My Ride: 2006 BMW 550i
does anybody have a list/translation of the german written options?
also, anybody have a list for what the bmw SA codes are?
Old 03-16-2012, 10:44 PM
  #659
gav900's Avatar
My Ride: BMW 530D E60
Anyone know how to disable the front headlights (dip and/or main beam) blown bulb error check? I've fitted xenon lights and the error checking plays havoc with them. I've coded some stuff already, just not sure where to look..
Thanks in advance
Gav
Old 03-24-2012, 12:37 PM
  #660
hollow's Avatar
ive been trying to code the angel eyes as the drls and disable the xenons . car is a late 2006 model ncs reports that i have an lm2 module (LM2_E6X.C35,A_E60LM2.IPO,LM_AHL_2.PRG)ive read the whole thread and found the part you have to enable to make the angel eyes active (DRL_TFL_SML_33 -. ACTIV) problem is this line of code is missing from my trace file . is it possible to just add the line of code and it will work or does the module have to be updated ?
also can someone tell me how to deactive the gong sound when the key is in the ignition ,its so annoying
sorry if this has been asked before
heres a copy of my trace file
PWM_ANST_FL_BIXENON
wert_04
NORM_LEUCHTWEITE
wert_01
wert_04
wert_11
wert_16
MAX_SW_SCHWENK_W_INNEN
wert_01
wert_04
wert_07
wert_10
wert_11
wert_12
wert_16
MAX_SW_SCHWENK_W_AUSSEN
wert_01
wert_04
wert_05
wert_06
wert_07
wert_10
wert_12
wert_14
wert_15
wert_16
wert_18
MAX_SW_SCHWENK_V_HORIZ
wert_01
wert_04
wert_07
wert_11
wert_16
MAX_SW_SCHWENK_V_VERTI
wert_01
wert_04
wert_07
wert_11
wert_13
wert_14
wert_15
wert_16
wert_17
wert_18
wert_19
wert_20
wert_21
wert_22
TAU_ABSCHWAECHUNG
wert_01
wert_04
wert_07
wert_11
wert_15
wert_16
LICHTZ_R_L_FAKTOR
wert_01
wert_04
wert_11
wert_16
SW_NULL_BEREICH
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_LO_SW_MITLENKEN
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_HI_SW_MITLENKEN
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
C_METER_NACH_INNEN_HI
wert_01
wert_04
wert_11
wert_16
V_LO_SW_NACH_INNEN
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_HI_SW_NACH_INNEN
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
KENNL_MAX_UEBERST
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
KENNL_REDUZ_MAX_SCHWENK
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
T_FILTER_UEBERST
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_LO_AENDER_LENK_UEBERS
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_HI_AENDER_LENK_UEBERS
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
T_FILTER_V_VEH
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_LO_RED_SCHWENK_W
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_HI_RED_SCHWENK_W
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
ABSCHW_D_TAU_LO
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
ABSCHW_D_TAU_HI
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_LO_ABSCHW_D_TAU
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_HI_ABSCHW_D_TAU
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
ABSCHWAECH_D_TAU
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_REFERENZLAUF_EN
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
MIN_SW_SCHWENK_V_HORIZ
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
AEND_V_SCHWENK_N_AUSSEN
wert_01
wert_04
wert_07
wert_11
wert_16
REDUZIERUNG_V_SCHWENK_LO
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_LO_REDUZIER_V_SCHWENK
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_M_LO_REDUZIER_V_SCHWENK
wert_01
wert_04
wert_05
wert_06
wert_07
wert_11
wert_16
REDUZIERUNG_V_SCHWENK_HI
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_M_HI_REDUZIER_V_SCHWENK
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_HI_REDUZIER_V_SCHWENK
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
MAX_VERRINGERUNG_V_SCHW
wert_01
wert_04
wert_07
wert_11
wert_16
MIN_DELTA_MAX_VERR
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
MAX_DELTA_KEINE_VERR
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
T_FILTER_LENKWINKEL
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
D_TAU_MITTEL_LENKW
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
T_FILTER_GIERRATE
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
D_TAU_MITTEL_GIERR
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_LO_TAU_GIERRATE
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_HI_TAU_GIERRATE
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
T_F_GIERRATE_DEF
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
SCHW_TAU_LW_GR
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
DRIFT_INKR
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
DRIFT_DEKR
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
DRIFT_SCHWELLE
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
T_FILTER_TAU_LW
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
T_FILTER_DYN_LZ
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
RAUSCH
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
ZEITK_TRIGGER1
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
MERKM_1_MAX
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
MERKM_1_BEGR
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
MERKM_1_INKR
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
MERKM_1_DEKR
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
ALC_KENNLIN_LWR_SENSOR_VO
wert_01
wert_04
wert_11
wert_13
wert_14
wert_20
wert_23
ALC_KENNLIN_LWR_SENSOR_HI
wert_01
wert_04
wert_07
wert_13
wert_18
wert_20
ALC_DEF_LWR_SENSOR_HI
wert_01
wert_04
wert_07
wert_12
ALC_LWR_NEIGUNG_KONSTANTE
wert_01
wert_04
wert_11
wert_18
ALC_EPSILON_DELTA_AV
wert_01
wert_04
wert_07
ALC_EPSILON_DELTA_A
wert_01
wert_04
ALC_ANHEBUNG_175_KM/H
wert_01
wert_04
wert_05
wert_06
wert_07
wert_10
wert_12
wert_13
wert_14
wert_15
ALC_ABSENKUNG_10_KM/H
wert_01
wert_04
wert_05
wert_06
wert_07
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
wert_17
ALC_VMAX_BESCHLEUNIGUNG
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
ALC_VMIN_BESCHLEUNIGUNG
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
ALC_VMAX_BREMSEN
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
wert_17
ALC_VMIN_BREMSEN
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
wert_17
ALC_SCHW_GRAD_BESCHLEUNIG
wert_01
wert_04
wert_07
wert_19
ALC_SCHW_GRAD_BREMSEN
wert_01
wert_04
wert_07
wert_19
ALC_SCHW_PROP_ABWEICHUNG
wert_01
wert_04
wert_07
wert_15
ALC_DIFFERENZ_MSP_DYN_STA
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
wert_17
ALC_DAUER_DYN_NACHFUEHR
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
wert_17
ALC_ABTASTRATE_DYN
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
wert_17
ALC_MITTELUNGSINTERV_DYN
wert_01
wert_04
wert_07
wert_11
wert_16
wert_17
ALC_MIN_STEIGUNG_VZ_WECHS
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
wert_17
ALC_MITTELUNGSINT_VZ_WECH
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
wert_17
ALC_MINDESTANZAHL_VZ_WECH
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_12
wert_13
wert_14
wert_15
ALC_HOEHENWEG
wert_01
wert_04
wert_05
wert_06
wert_07
ALC_ABTASTRATE_TREND
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
wert_17
ALC_MITTELUNGSINTERV_TREN
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
wert_17
ALC_SCHW_TREND
wert_01
wert_04
wert_05
wert_06
wert_07
ALC_ABWEICHUNG_TREND
wert_01
wert_04
wert_05
wert_06
wert_07
ALC_NACHLAUF_SCHLECHTWEG
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
wert_17
CKM_ALC
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
CKM_ALC_DEF
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
MIN_SW_SCHWENK_V_VERTI
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
KALTUEBERWACHUNG_FL_L
aktiv
KALTUEBERWACHUNG_FL_R
aktiv
KALTUEBERWACHUNG_SL_V_L
aktiv
KALTUEBERWACHUNG_SL_V_R
aktiv
KALTUEBERWACHUNG_NSW_L
aktiv
KALTUEBERWACHUNG_NSW_R
aktiv
KALTUEBERWACHUNG_BLK_V_L
aktiv
KALTUEBERWACHUNG_BLK_V_R
aktiv
KALTUEBERWACHUNG_BLK_H_L
aktiv
KALTUEBERWACHUNG_BLK_H_R
aktiv
KALTUEBERWACHUNG_BL_M_1
nicht_aktiv
HEIMLEUCHTEN_FUNKSCHL
nicht_aktiv
KALTUEBERWACHUNG_KZL_L
aktiv
KALTUEBERWACHUNG_KZL_R
aktiv
KALTUEBERWACHUNG_RFS_L
aktiv
MIND_ANZ_ZYKL_TIPP_BLK
wert_02
ALC_ZUSTANDS_AUTOM
wert_02
DEF_HEIMLEUCHTEN_CKM
wert_02
DEF_ZYKL_TIPP_BLK_CKM
wert_02
KALTUEBERWACHUNG_RFS_R
aktiv
WARMUEBERWACHUNG_FL_L
aktiv
WARMUEBERWACHUNG_FL_R
aktiv
WARMUEBERWACHUNG_AL_L
aktiv
WARMUEBERWACHUNG_AL_R
aktiv
WARMUEBERWACHUNG_SL_V_L
aktiv
WARMUEBERWACHUNG_SL_V_R
aktiv
WARMUEBERWACHUNG_NSW_L
aktiv
WARMUEBERWACHUNG_NSW_R
aktiv
WARMUEBERWACHUNG_BLK_V_L
aktiv
WARMUEBERWACHUNG_BLK_V_R
aktiv
WARMUEBERWACHUNG_BLK_H_L
aktiv
WARMUEBERWACHUNG_BLK_H_R
aktiv
WARMUEBERWACHUNG_BL_M_1
nicht_aktiv
WARMUEBERWACHUNG_KZL_L
aktiv
WARMUEBERWACHUNG_KZL_R
aktiv
WARMUEBERWACHUNG_RFS_L
aktiv
WARMUEBERWACHUNG_RFS_R
aktiv
TASTVERH_KL_58G_MIN
wert_01
ZUWACHS_TASTVERH_KL_58G
wert_01
VERHALTEN_UEBERWACHUNG
wert_01
FEHLERMELDUNG_CC_FL_L
aktiv
FEHLERMELDUNG_CC_FL_R
aktiv
FEHLERMELDUNG_CC_AL_L
aktiv
FEHLERMELDUNG_CC_AL_R
aktiv
FEHLERMELDUNG_CC_SL_V_L
aktiv
FEHLERMELDUNG_CC_SL_V_R
aktiv
FEHLERMELDUNG_CC_BLK_V_L
aktiv
FEHLERMELDUNG_CC_BLK_V_R
aktiv
FEHLERMELDUNG_CC_BLK_H_L
aktiv
FEHLERMELDUNG_CC_BLK_H_R
aktiv
ALC_ERR_NSW_ZUSCHALTEN
aktiv
ALC_CC_127_ZUST_5_OFF
aktiv
ALC_CC_AL_OFF
nicht_aktiv
FEHLERMELD_CC_RL_BL_2_L
nicht_aktiv
FEHLERMELD_CC_RL_BL_2_R
nicht_aktiv
FEHLERMELDUNG_CC_KZL_L
aktiv
FEHLERMELDUNG_CC_KZL_R
aktiv
WARNBLK_ENERGY_SAVE_MODE
aktiv
FEHLERMELDUNG_CC_RFS_L
aktiv
FEHLERMELDUNG_CC_RFS_R
aktiv
LEUCHTDICHTE_EXPO
nicht_aktiv
LENKWINKEL_UEBERSCHREITEN
wert_01
LENKWINKEL_UNTERSCHREITEN
wert_01
LENKSTOCK_UMSCHALT_VERZ
wert_01
U_POTI_DIMM_MIN
wert_02
U_POTI_DIMM_DELTA
wert_02
MELDUNG_AENDERUNG_DIMMER
wert_01
POTI_DIMM_INVERS
aktiv
POTI_LWR_INVERS
nicht_aktiv
HEIMLEUCHTEN_VERLAENG
nicht_aktiv
CRASH_58G_EIN
aktiv
BLINKIMPULS_WARNBLK
wert_01
BLINKIMPULS_CRASHBLK
wert_01
WERT_CRASHVERHALTEN
wert_01
CRASH_WARNBLINKEN
aktiv
BFD_1_RL_BL_1_ERSCH_BILD
wert_01
BFD_1_RL_BL_2_ERSCH_BILD
nicht_aktiv
PWM_ANSTEUERUNG_BL_M_1
wert_01
ALC_ENPRELL_AL_OK
wert_01
SL_V_PARKL_FKT
aktiv
ALC_ENPRELL_AL_NIO
wert_01
RL_BL_1_PO_RL_FKT
aktiv
AUTOM_LICHT_KONTROLLE
aktiv
ALC_DEFEKT_TIMER
wert_01
ALC_EIN_DAEMMERUNGSSTUFE
wert_01
ALC_REF_LAUF_AL_AUS
wert_01
LWR_TREIBER_CODIERUNG_2
wert_01
SIDEMARKER_US
aktiv
ALC_CC_127_ZUST_4_OFF
aktiv
AUTOM_LICHT_ABSCHALTUNG
nicht_aktiv
BI_XENON_BEI_LH
nicht_aktiv
TIPP_BLK_LOESCHT_IMMER
aktiv
HEIMLEUCHTEN_ABBRUCH
nicht_aktiv
MAX_BETAETIGUNG_FOMEHO
wert_01
LWR_TESTBETRIEB
nicht_aktiv
LWR_FEHLER_BEWERTUNG
wert_02
LWR_SCHRITTABSTAND_GRENZE
wert_01
LWR_TEMPERATUR_GRENZE
grad_-20
SCHRITTABSTAND_STARTPHASE
wert_01
KEINE_PARKLICHT_FUNKT
nicht_aktiv
FL_ABSCHALT_OPT
nicht_aktiv
HALB/VOLLSCHRITT
halbschritt
U_LWR_POTI_STELLUNG_0
wert_01
U_LWR_POTI_STELLUNG_1
wert_01
U_LWR_POTI_STELLUNG_2
wert_01
BLEND_CHECK_IST_WINKEL
aktiv
BLEND_CHECK_SOLL_WINKEL
nicht_aktiv
SL_V_PO_RL_FKT
aktiv
NOTLAUF_FKT_GESCHW
wert_01
WARNBLK_TASTE_KL58G
nicht_aktiv
LOAD_DUMP_SCHUTZ_AKTIV
aktiv
NOTLAUF_FKT_SCHALTERSTELL
aktiv
LOAD_DUMP_MAX_TIME
wert_01
LOAD_DUMP_PRELL
wert_03
LOAD_DUMP_SCHUTZ_KL58G
aktiv
LOAD_DUMP_DIMM_WERL_BLK
wert_01
BFD_1_BL_M_ERSCH_BILD
wert_01
AL_KL50_SCHUTZ
nicht_aktiv
BFD_1_RL_BL_ERSCH_BILD
wert_01
BFD_1_WEGFALL
nicht_aktiv
BFD_1_MIN_GESCHW
wert_01
BFD_1_THERM_TIMEOUT
wert_01
BFD_1_WERT_AX_RUCK
wert_01
BFD_1_STUFE_DELAY
wert_01
BFD_1_BLINK_FREQ_AUS
wert_01
BFD_1_BLINK_FREQ_EIN
wert_01
BFD_1_ENTPRELL_ABS
wert_01
BFD_1_ENTPRELL_AX
wert_01
BFD_2_THERM_TIMEOUT
wert_01
BFD_2_ALGORITHMUS
nicht_aktiv
BFD_2_RL_BL_1_ERSCH_BILD
wert_01
BFD_2_RL_BL_2_ERSCH_BILD
nicht_aktiv
BFD_2_RL_BL_ERSCH_BILD
wert_01
BFD_2_NSL_ERSCH_BILD
nicht_aktiv
BFD_2_WEGFALL
nicht_aktiv
BFD_2_MIN_GESCHW
wert_01
BFD_2_WERT_AX_RUCK
wert_01
BFD_2_STUFE_DELAY
wert_01
BFD_2_BLINK_FREQ_AUS
wert_03
BFD_2_BLINK_FREQ_EIN
wert_03
BFD_2_ENTPRELL_ABS
wert_01
BFD_2_ENTPRELL_AX
wert_01
RL_BL_BREMSL_FKT
aktiv
STANDKLIMA
nicht_aktiv
RL_BL_2_BREMSL_FKT
nicht_aktiv
ALC_ERR_BLK_FREQ
wert_01
ALC_CC_ALC_ERR_OFF
nicht_aktiv
PROGRAMMPARAM_ALC_SG_1
wert_01
PROGRAMMPARAM_ALC_SG_2
wert_01
CAN_11H
nicht_aktiv
SCHALTER_R_GANG
nicht_aktiv
ABSTELLPOS_SMC
aktiv
ABSTELLPOS_CUSTOM
nicht_aktiv
ALC_AUSWERT_GRADIENT
aktiv
ALC_AUSWERT_PROP_ABWEICH
aktiv
ALC_EINSCHALTBEDINGUNG
wert_01
ALC_GRADIENT_SCHLECHTWEG
nicht_aktiv
ALC_KLS_ENABLE
aktiv
KLASSIF_LENKM_ENA
aktiv
ALC_SCHW_GRAD_SCHLECHTWEG
wert_01
ALC_SCHWENK_LATCH
aktiv
ALC_SAETT_TIMER_SCHLECHTW
aktiv
ERR_LWR_L_IGNORIEREN
nicht_aktiv
ERR_LWR_R_IGNORIEREN
nicht_aktiv
ERR_SCHWENK_R_IGNORIEREN
nicht_aktiv
IK_BUS_TEILNEMER
nicht_aktiv
KLS_BEI_AL_AKTIV
nicht_aktiv
KEINE_L_R_SYNCHRONISATION
nicht_aktiv
KLASSIF_UEBERST_ENA
aktiv
OHNE_GIERRATE
nicht_aktiv
KLASSIF_DRIFT_ENA
aktiv
ERR_SCHWENK_L_IGNORIEREN
nicht_aktiv
LWR_ABSTELLPOS
wert_01
TASTVERH_BEL_WBL_MIN
wert_02
KALTUEBERWACHUNG_BL_L
aktiv
KALTUEBERWACHUNG_BL_R
aktiv
KALTUEBERW_RL_BL_1_L
aktiv
KALTUEBERW_RL_BL_1_R
aktiv
WARMUEBERWACHUNG_BL_L
aktiv
WARMUEBERWACHUNG_BL_R
aktiv
WARMUEBERW_RL_BL_1_L
aktiv
WARMUEBERW_RL_BL_1_R
aktiv
FEHLERMELDUNG_CC_BL_L
aktiv
FEHLERMELDUNG_CC_BL_R
aktiv
FEHLERMELD_CC_RL_BL_1_L
aktiv
FEHLERMELD_CC_RL_BL_1_R
aktiv
ZUWACHS_TASTVERH_WBL_BEL
wert_02
RL_BL_PARKL_FKT
aktiv
PWM_ANST_RL_BL_2_BL
wert_01
PWM_ANST_RL_BL_1_BL
wert_01
BFD_1_ALGORITHMUS
aktiv
TAGFAHRLICHT_ECE
aktiv
DEF_TAGFAHRLICHT_ECE_CKM
nicht_aktiv
LWR_ANSTEUERN
nicht_aktiv
ALC_FAHRZEUG
aktiv
UMSCHALTOPT_LICHTSCHALTER
aktiv
XENON_AL_VERBAUT
aktiv
KALTUEBERWACHUNG_AL_L
nicht_aktiv
KALTUEBERWACHUNG_AL_R
nicht_aktiv
LWR_HYSTERESE_START
wert_02
LWR_VORBESTROMUNG
wert_02
XENON_LI
wert_01
wert_02
KALTUEBERW_RL_BL_2_L
nicht_aktiv
KALTUEBERW_RL_BL_2_R
nicht_aktiv
WARMUEBERW_RL_BL_2_L
nicht_aktiv
WARMUEBERW_RL_BL_2_R
nicht_aktiv
QUITT_BLK_SICHERN
nicht_aktiv
QUITT_BLK_ENTSICHERN
nicht_aktiv
DEF_QUITT_BLK_ENTSI_CKM
nicht_aktiv
DEF_QUITT_BLK_SICH_CKM
nicht_aktiv
RECHTSVERKEHR
nicht_aktiv
LINKSVERKEHR
aktiv
FL_UND_NSW_NICHT_GLEICHZ
nicht_aktiv
BFD_1_WERT_AX_EIN
wert_02
wert_03
KALTUEBERWACHUNG_NSL_L
aktiv
KALTUEBERWACHUNG_NSL_R
aktiv
WARMUEBERWACHUNG_NSL_L
aktiv
WARMUEBERWACHUNG_NSL_R
aktiv
BFD_2_BL_M_ERSCH_BILD
wert_02
FEHLERMELDUNG_CC_NSL_L
aktiv
FEHLERMELDUNG_CC_NSL_R
aktiv
BFD_2_WERT_AX_EIN
wert_01
BFD_1_NSL_ERSCH_BILD
nicht_aktiv
LENK_UEBERSETZUNG
wert_01
wert_02
wert_05
wert_06
wert_15
wert_25
LENK_UEBERSETZUNG_LO
wert_01
wert_02
wert_05
wert_06
wert_07
wert_08
wert_09
wert_10
wert_11
wert_14
wert_15
wert_16
wert_17
wert_18
wert_19
wert_20
WINKEL_BLENDUNG
wert_01
ALC_LWR_VORZEICHEN
beide_aktiv
CHECK_FGN_SMC_ALC_OFF
aktiv
COMFORT_ACCESS_LICHT
aktiv
CHECK_SMC_ERROR
aktiv
BFD_1_DEAKTIV_BEI_NSL
aktiv
BEHOERDEN_FZG
nicht_aktiv
BEHRD_FZG_ASYNCHRON_BLK
nicht_aktiv
DUAL_SP__AL_L
nicht_aktiv
DUAL_SP__AL_R
nicht_aktiv
DUAL_SP__FL_L
aktiv
DUAL_SP__FL_R
aktiv
DUAL_SP__KZL_L
aktiv
DUAL_SP__KZL_R
aktiv
DUAL_SP__NSL_L
aktiv
DUAL_SP__NSL_R
aktiv
DUAL_SP__NSW_L
aktiv
DUAL_SP__NSW_R
aktiv
DUAL_SP__SL_V_L
aktiv
DUAL_SP__SL_V_R
aktiv
DUAL_SP_PARAMETER
wert_01
GESCHW_DOWN
wert_01
wert_02
GESCHW_UP
wert_01
wert_02
PROZENT_EE
wert_01
PWM_ANSTEUERUNG_NSW
wert_01
QUITT_BLK_IGNORE_MOTORH
aktiv
ALC_SCHWENK_BEI_S_FLC
nicht_aktiv
FLC_OHNE_RLS
nicht_aktiv
UNTERDRUECK_BL_BLITZEN
aktiv
TIPP_BLK_ABBRUCH
aktiv
TIPP_BLK_ABBRUCH_IMMER
aktiv
QUITT_BLK_ZU_CHECK_1
aktiv
SMART_BEAM
nicht_aktiv
IBUS_R_GANG
nicht_aktiv
FL_ASSIST_FUNKTIONS_ANZ
nicht_aktiv
LWR_TERMO_MODEL_EIN
aktiv
HECKD_REV_BLK_DOPPELB
aktiv
HECKDECK_REVERS_BLK
wert_01
ALC_NSW_BEDIEN_MOEGL
aktiv
CC_MELD_SW_CI_NOT_AKTIV
nicht_aktiv
CI_KODIERDATEN
wert_01
FL_ASSIST_CC_NOT_AKTIV
aktiv
FL_ASSIST_ZUST_22_32
nicht_aktiv
NEUE_FAHRT_BEI_SICHERN
aktiv
NEUE_FAHRT_BEI_SLEEP
aktiv
NEUE_FAHRT_KL_15_NACHL
nicht_aktiv
ALC_FAILSAVE_AHL
aktiv
FL_AUS_BEI_BIX_IN_S_FLC
nicht_aktiv
FSP_MASKIERUNG
wert_01
ISP_MASKIERUNG
wert_01
LS_UMSCHALT_FEHLER_ZEIT
wert_01
ABBIEGELICHT_CKM_0
nicht_aktiv
ABBIEGELICHT_CKM_1
aktiv
ABBIEGELICHT_CKM_2
nicht_aktiv
ABBIEGELICHT_CKM_3
nicht_aktiv
ABK_KNICK
wert_01
ABK_MIN_PROZ
wert_01
ABK_VERLAENG
wert_01
ABSCHALTUNG_RFS_1
aktiv
ABSCHW_D_TAU_HI_SP
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
ABSCHW_D_TAU_LO_SP
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
ABSCHWAECH_D_TAU_SP
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
AEND_V_SCHWENK_N_AUSSE_SP
wert_01
wert_04
wert_07
wert_11
wert_16
AHL_MODE_CKM_0
wert_01
AHL_MODE_CKM_1
wert_03
AHL_MODE_CKM_2
wert_01
AHL_MODE_CKM_3
wert_01
ALC_ERR_BLK_AL_EIN
aktiv
ALC_SCHWENK_IM_STAND
aktiv
BFD_2_DEAKTIV_BEI_NSL
nicht_aktiv
CC_MELD_NSL_BFD
nicht_aktiv
CC_MELD_NSL_SL
nicht_aktiv
DEF_ABBIEGELICHT_CKM
nicht_aktiv
DEF_AHL_MODE_CKM
wert_01
DEF_SMART_BEAM_CKM
nicht_aktiv
DEF_WELCOMELIGHT_CKM
nicht_aktiv
DUAL_SP__BL_L
nicht_aktiv
DUAL_SP__BL_M_1
nicht_aktiv
DUAL_SP__BL_R
nicht_aktiv
DUAL_SP__BLK_H_L
nicht_aktiv
DUAL_SP__BLK_H_R
nicht_aktiv
DUAL_SP__BLK_V_L
nicht_aktiv
DUAL_SP__BLK_V_R
nicht_aktiv
DUAL_SP__RFS_L
nicht_aktiv
DUAL_SP__RFS_R
nicht_aktiv
DUAL_SP__RL_BL_1_L
nicht_aktiv
DUAL_SP__RL_BL_1_R
nicht_aktiv
DUAL_SP__RL_BL_2_L
nicht_aktiv
DUAL_SP__RL_BL_2_R
nicht_aktiv
EINLENKEN_RKW
aktiv
ENTGEGENGES_RKW
aktiv
FEHLERMELDUNG_CC_BL_M_2
nicht_aktiv
FEHLERMELDUNG_CC_SML_L
nicht_aktiv
FEHLERMELDUNG_CC_TFL_L
nicht_aktiv
FEHLERMELDUNG_CC_TFL_R
nicht_aktiv
FSP_ISP_SPERREN_1
wert_00
GETRIEBE_HANDSCHALTER
nicht_aktiv
HEIMLEUCHTEN_2
wert_02
HEIMLEUCHTEN_3
wert_02
HEIMLEUCHTEN_ENABLE
aktiv
HEIZ_ANF
wert_01
HEIZ_KNICK
wert_01
KALTUEBERWACHUNG_TFL_L
aktiv
KALTUEBERWACHUNG_TFL_R
aktiv
KENNL_MAX_UEBERST_SP
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
KENNL_REDUZ_MAX_SCHWEN_SP
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
KURZSCHL_WIERHOL_ZAEHLER
wert_01
KURZSCHLUSS_CHECK_DISA
wert_01
KURZSCHLUSS_CHECK_TIME
wert_01
KURZSCHLUSS_ENTPRELL
wert_01
LENK_UEBERSETZUNG_LO_SP
wert_01
wert_02
wert_05
wert_06
wert_07
wert_08
wert_09
wert_10
wert_11
wert_14
wert_15
wert_16
wert_17
wert_18
wert_19
wert_20
MAX_DELTA_KEINE_VERR_SP
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
MAX_HEIZZEIT
wert_01
wert_03
wert_04
wert_05
MAX_VERRINGERUNG_V_SCH_SP
wert_01
wert_04
wert_07
wert_11
wert_16
MIN_DELTA_MAX_VERR_SP
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
MIN_SW_SCHWENK_V_HORIZ_SP
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
MIND_ANZ_ZYKL_TIPP_BLK_1
wert_02
MIND_ANZ_ZYKL_TIPP_BLK_2
wert_02
MIND_ANZ_ZYKL_TIPP_BLK_3
wert_02
NACHL_RKW
wert_01
NO_BLK_RKW
nicht_aktiv
NSL_BREMSL_FKT
nicht_aktiv
NSL_ERS_DEF_RL_BL_1
nicht_aktiv
NSL_VERBAU_OTP
wert_01
PWM_NSL_ODER_BFD_ALS_BL
wert_01
PWM_SIDEMARKER_BLK_V
wert_01
QUITT_BLK_ENTSICHERN_1
nicht_aktiv
QUITT_BLK_ENTSICHERN_2
nicht_aktiv
QUITT_BLK_ENTSICHERN_3
nicht_aktiv
QUITT_BLK_SICHERN_1
nicht_aktiv
QUITT_BLK_SICHERN_2
nicht_aktiv
QUITT_BLK_SICHERN_3
nicht_aktiv
RAMPE_AUS_BLK
wert_01
RAMPE_AUS_KRV
wert_01
RAMPE_AUS_RUE
wert_01
RAMPE_EIN_BLK
wert_01
RAMPE_EIN_KRV
wert_01
RAMPE_EIN_RUE
wert_01
REDUZIERUNG_V_SCHWE_HI_SP
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
REDUZIERUNG_V_SCHWE_LO_SP
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
SL_BL_ERS_DEF_RL_BL_1
nicht_aktiv
SMART_BEAM_CKM_0
nicht_aktiv
SMART_BEAM_CKM_1
nicht_aktiv
SMART_BEAM_CKM_2
nicht_aktiv
SMART_BEAM_CKM_3
nicht_aktiv
SP_GRENZE
wert_01
START_ABBL
wert_01
SW_NULL_BEREICH_SP
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
T_FILTER_UEBERST_SP
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
T_FILTER_V_VEH_SP
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
TAGFAHRLICHT_ECE_1
nicht_aktiv
TAGFAHRLICHT_ECE_2
nicht_aktiv
TAGFAHRLICHT_ECE_3
nicht_aktiv
TASTVERH_BEL_FLC_LED
wert_03
TAU_ABSCHWAECHUNG_SP
wert_01
wert_04
wert_07
wert_11
wert_15
wert_16
UNP_ABBIEGELICHT_CKM
nicht_aktiv
UNP_AHL_MODE_CKM
wert_01
UNP_HEIMLEUCHTEN_CKM
wert_02
UNP_QUITT_BLK_ENTSI_CKM
nicht_aktiv
UNP_QUITT_BLK_SICH_CKM
nicht_aktiv
UNP_SMART_BEAM_CKM
nicht_aktiv
UNP_TAGFAHRLICHT_ECE_CKM
nicht_aktiv
UNP_WELCOMELIGHT_CKM
nicht_aktiv
UNP_ZYKL_TIPP_BLK_CKM
wert_02
V_E_HI_BLK
wert_01
V_E_HI_KRV
wert_01
wert_04
wert_07
V_E_LO_BLK
wert_01
V_E_LO_KRV
wert_01
wert_04
wert_07
V_HI_ABSCHW_D_TAU_SP
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_HI_AENDER_LENK_UEBER_SP
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_HI_RED_SCHWENK_W_SP
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_HI_REDUZIER_V_SCHWEN_SP
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_HI_SW_MITLENKEN_SP
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_HI_SW_NACH_INNEN_SP
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_LO_ABSCHW_D_TAU_SP
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_LO_AENDER_LENK_UEBER_SP
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_LO_RED_SCHWENK_W_SP
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_LO_REDUZIER_V_SCHWEN_SP
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_LO_SW_MITLENKEN_SP
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_LO_SW_NACH_INNEN_SP
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_M_HI_REDUZIER_V_SCHW_SP
wert_01
wert_04
wert_05
wert_06
wert_07
wert_09
wert_10
wert_11
wert_12
wert_13
wert_14
wert_15
wert_16
V_M_LO_REDUZIER_V_SCHW_SP
wert_01
wert_04
wert_05
wert_06
wert_07
wert_11
wert_16
V_S_HI_BLK
wert_01
V_S_HI_KRV
wert_01
V_S_LO_BLK
wert_01
V_S_LO_KRV
wert_01
WARMUEBERWACHUNG_TFL_L
aktiv
WARMUEBERWACHUNG_TFL_R
aktiv
WELCOMELIGHT_CKM_0
nicht_aktiv
WELCOMELIGHT_CKM_1
aktiv
WELCOMELIGHT_CKM_2
nicht_aktiv
WELCOMELIGHT_CKM_3
nicht_aktiv
ZUWACHS_TASTVERH_FLC_LED
wert_03
DUAL_SP__BLK_2_VL
nicht_aktiv
DUAL_SP__BLK_2_VR
nicht_aktiv
DUAL_SP__SML
nicht_aktiv
DUAL_SP__TFL_L
nicht_aktiv
DUAL_SP__TFL_R
nicht_aktiv
FEHLERMELDUNG_CC_BLK_2_VL
nicht_aktiv
FEHLERMELDUNG_CC_BLK_2_VR
nicht_aktiv
KALTUEBERWACHUNG_BLK_2_VL
nicht_aktiv
KALTUEBERWACHUNG_BLK_2_VR
nicht_aktiv
PWM_ANST_1_UNBELEGT
wert_01
WARMUEBERWACHUNG_BLK_2_VL
nicht_aktiv
WARMUEBERWACHUNG_BLK_2_VR
nicht_aktiv
FEHLERMELD_CC_NSW_L
aktiv
FEHLERMELD_CC_NSW_R
aktiv
PWM_ANST_2_UNBELEGT
wert_01
PWM_ANST_3_UNBELEGT
wert_01
BLK_TIMER_STAND
wert_01
HYST_STAND_KRV
wert_01
MAX_SCHWENK_V_H_BEGR
wert_01
wert_04
wert_07
wert_11
wert_13
wert_14
wert_16
MAX_SCHWENK_V_H_BEGR_SP
wert_01
wert_04
wert_07
wert_11
wert_16
PWM_FL_NSW_FKT_ABBLIEGELI
wert_01
SENSEWID_PIN_22_68
aktiv
SENSEWID_PIN_24_39
aktiv
SENSEWID_PIN_30
aktiv
SENSEWID_PIN_42
aktiv
SL_ABSCH_OHNE_ECE
aktiv
TIMEOUT_SET_DTC
aktiv
WELCOME_LIGHT_ACTIVE
aktiv
WL_AL
nicht_aktiv
WL_BLK_H
nicht_aktiv
WL_BLK_V
nicht_aktiv
WL_DAUER
wert_01
WL_FL
nicht_aktiv
WL_KZL
soft_einschalten
WL_MAX_DAUER
wert_01
WL_NSL
nicht_aktiv
WL_NSW
nicht_aktiv
WL_POL
aktiv
WL_SL_1
nicht_aktiv
WL_SL_2
hart_einschalten
AUTO_LWR_ENABLE_LM2
aktiv
DYNAM_LWR_ENABLE_LM2
aktiv
ABBL_LZ_RKW
wert_01
ABBL_LZ_STAND
wert_01
BL_2_PARKL_FKT
nicht_aktiv
BL_2_RL_FKT
nicht_aktiv
CC_MELD_AL_OFF
nicht_aktiv
CC_MELD_PARKLICHT
nicht_aktiv
DRL_TFL_BLK_V_GED
nicht_aktiv
DRL_TFL_KZL
nicht_aktiv
DRL_TFL_RL_BL
nicht_aktiv
ENDE_ABBL
wert_01
HW_NOTLAUF_CHECK_COUNT
wert_02
HYST_RKW
wert_01
LH_UND_NSW_NICHT_GLEICHZ
nicht_aktiv
LICHT_AN_WARN_NORM
aktiv
PWM_ANST_BL_2_SL
wert_01
PWM_ANSTEUERUNG_BL
wert_05
PWM_PIN_22_68_24_39
wert_02
PWM_PIN_25_40
wert_04
RLS_RESTART_COMM
wert_01
RLS_VERBAUT
nicht_aktiv
TIPP_BLK
nicht_aktiv
ABL_AUS_BEI_FL_LH_EIN
aktiv
BFD_1_BL_2_ERSCH_BILD
nicht_aktiv
BFD_2_BL_2_ERSCH_BILD
nicht_aktiv
CC_MEL_SL_BEI_DEF_RL_BL_1
nicht_aktiv
DWA_UEBERFALL_ALARM
wert_02
ENERGIE_UBATT_LIMIT
wert_01
ENERGIE_ZEIT_ENTPRELL
wert_01
ENERGIE_ZEIT_LIMIT
wert_01
FSP_LAMPEN_MASK
wert_01
FZG_RADSTAND_LM
wert_01
wert_04
wert_11
wert_17
KALTUEBERWACHUNG_SML
nicht_aktiv
LOAD_DUMP_DIMM_AL
aktiv
LOAD_DUMP_DIMM_BL
aktiv
LWR_MAX_POS_NORM
wert_01
LWR_MAX_POS_REF
wert_01
LWR_OFFSET_PLATTLAUF_L
wert_01
LWR_OFFSET_PLATTLAUF_R
wert_01
NSL_AUS_BEI_FE_MODE
nicht_aktiv
SL_SCHALT_UMSCHALT_OPT
wert_01
STANDVERBRAUCHER_ANMELD
aktiv
VORH_HEIZZ
wert_01
WARMUEBERWACHUNG_SML
nicht_aktiv
WL_MIT_FLC
nicht_aktiv
WL_ZYKLEN
wert_01
ALC_SG_VERBAUT
nicht_aktiv
BL_2_BREMSL_FKT_33
nicht_aktiv
CC_MELD_ABIEGL_BEI_DEF_FL
nicht_aktiv
DRL_TFL_RL_BL_1_33
nicht_aktiv
DRL_TFL_RL_BL_2_33
nicht_aktiv
DRL_TFL_SML_33
nicht_aktiv
DRL_TFL_TFL_33
nicht_aktiv
LWR_ABS_MIN_STELL_2
wert_02
LWR_SCHRITTE_STELL_0
wert_02
LWR_SCHRITTE_STELL_1
wert_02
LWR_SCHRITTE_STELL_2
wert_02
PIN_CONFIGURATION_33
wert_01
PWM_AN_NSL_SL
wert_02
wert_03
PWM_ANS_RL_BL_2_AL_33
wert_03
PWM_ANS_RL_BL_2_FL_33
wert_03
PWM_ANST_RL_BL_BL_33
wert_01
PWM_ANSTEUERUNG_NSL_33
wert_01
PWM_ANSTEUERUNG_RL_33
wert_05
PWM_FL_FKT_DRL_33
wert_01
PWM_PIN_11_63_33
wert_02
PWM_RL_BL_1_FKT_PARKL_33
wert_04
RL_BL_1_BREMSL_FKT_33
nicht_aktiv
RL_BL_1_PARKL_FKT_33
nicht_aktiv
RL_BL_2_PARKL_FKT_33
nicht_aktiv
RL_BL_2_PO_RL_FKT_33
nicht_aktiv
RL_BL_PO_RL_FKT_33
aktiv
SENSEWID_PIN_04_33
aktiv
SENSEWID_PIN_05_33
nicht_aktiv
SENSEWID_PIN_10_33
aktiv
SENSEWID_PIN_11_33
nicht_aktiv
SENSEWID_PIN_25_33
aktiv
SENSEWID_PIN_40_33
aktiv
SENSEWID_PIN_61_33
aktiv
SENSEWID_PIN_62_33
nicht_aktiv
SENSEWID_PIN_63_33
nicht_aktiv
SENSEWID_PIN_64_33
aktiv
SL_PARKL_ABSCH_12H
nicht_aktiv
VERHALTEN_DRL_TFL_33
drl_s
PWM_ANSTEUERUNG_SML_33
wert_01
ENABLE_KL_GR_BL
nicht_aktiv
ENABLE_KL_VA
nicht_aktiv
PWM_BL1__GR_BL
wert_03
PWM_BL1__KL_BL
wert_02
PWM_BL2__GR_BL
wert_03
ENABLE_RL1_ERS_BL1
aktiv
IGR_MIT_SL_AL
aktiv
PWM_ANSTEUERUNG_AL_33
wert_01
PWM_ANSTEUERUNG_KZL_33
wert_01
PWM_RL1_ERS_BL1
wert_01
WL_BL
nicht_aktiv
WL_SM
soft_einschalten
LWR_MAX_POS_NORM_2
wert_02
LWR_DIAG_ANSTIEG
wert_01
wert_02
LWR_DIAG_OFFSET
wert_01
ZEIT_PARKL_AKTIVIERUNG
wert_03
AG_M_ALWR
wert_01
AHL2_ENABLE
nicht_aktiv
ALC_DIS_AUSGL_NICK_GW
nicht_aktiv
ALWR_ENABLE
nicht_aktiv
C1_HORI_BF
wert_01
C1_HORI_FA
wert_01
C1_VERT_BF
wert_01
C1_VERT_FA
wert_01
C2_HORI_BF
wert_01
C2_HORI_FA
wert_01
C2_VERT_BF
wert_01
C2_VERT_FA
wert_01
E__HORI_BF
wert_01
E__HORI_FA
wert_01
wert_02
E__VERT_BF
wert_01
E__VERT_FA
wert_01
wert_02
LWR_DIAG_ANSTIEG_2
wert_01
wert_02
LWR_DIAG_OFFSET_2
wert_01
NSW_AUTOBAHN
wert_02
OFFSET_GESCHW
wert_02
REF_DEMO
wert_01
V__HORI_BF
wert_01
V__HORI_FA
wert_01
V__VERT_BF
wert_01
V__VERT_FA
wert_01
VERZ_REF_DEMO
wert_01
wert_02
ALC_OFFSET_LWR_34
wert_01
wert_04
E3_HORI_BF
wert_01
E3_HORI_FA
wert_01
E3_VERT_BF
wert_01
E3_VERT_FA
wert_01
F_A_ALWR
wert_01
F_ALWR
wert_01
F_SWEG_ALWR
wert_01
GL_ALWR
wert_01
LWR_HEBEL_34
wert_02
MAX_KRUEMM
wert_01
PWM_AN_BLK_H_34
wert_02
PWM_AN_SL_V_AL_1_34
wert_03
wert_07
PWM_AN_SL_V_FL_1_34
wert_03
wert_08
PWM_ANSTEUERUNG_RFS_34
wert_02
PWM_PIN_05_62_34
wert_02
R_SWEG_ALWR
wert_01
STRST_MAXDIFF_ALWR
wert_01
T_ALWR_AM
wert_01
T_ALWR_AUS
wert_01
T_ALWR_MKR
wert_01
T_ALWR_NST
wert_01
T_ALWR_SW
wert_01
V_ALWR_AM
wert_01
V_ALWR_AN
wert_01
V_ALWR_AUS
wert_01
V_ALWR_BAB1
wert_01
V_ALWR_BAB2
wert_01
V_HI_AUTOB
wert_01
V_HI_STADT
wert_01
V_LO_AUTOB
wert_01
V_LO_STADT
wert_01
V_MID_LANDSTR
wert_01
V_MIN_KRUEMM
wert_01
V_NSW
wert_01
W_ALWR_EKR
wert_01
W_ALWR_MKR
wert_01
W_ALWR_SW
wert_01
WEG_GERADE
wert_01
Z_ALWR_NST
wert_01
Z_ALWR_SW
wert_01
ZEIT_AUTOB
wert_01
PWM_ANSTEUERUNG_FL_34
wert_02
CC_MEL_POL_BEI_DEF_TFL
nicht_aktiv
CC_MEL_SL_BEI_DEF_RL_BL_2
nicht_aktiv
Quick Reply: Car Coding
