Car Coding
Old 02-22-2011, 05:09 AM
  #381
Ehssan's Avatar
My Ride: Many BMW's
anyone knows how to keep the climate off when switch on the car ??
Old 02-22-2011, 07:58 AM
  #382
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Ehssan, what about what I mentioned above? I thought DRL is only on during the day? So at night time, when your low beams are on, they switch off.
Old 02-22-2011, 08:43 AM
  #383
BlaSTiWi's Avatar
But when you turn the parking lights on the AE will be on, right? So the AE will get turn on by 2 sources ... the OEM way (via light switch) & the hack way wired from hi-beam.
Old 02-22-2011, 09:43 AM
  #384
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Well actually, unless you keep the wiring from the AE as well, switching it to parking light will not have it one. But if I am taking this in correctly, Ehssan's directions above does keep the original AE wiring. The problem is though, that at night time, you can't just run your parking lights and not low beams. That wouldn't be safe at all.
Or you could just hit high beam and have it on at all times, but you'll have that blue icon in the cluster which may or may not bother some people.
Old 02-22-2011, 10:58 PM
  #385
Ehssan's Avatar
My Ride: Many BMW's
Exactly ,, that's why the OEM AE wire stays connected , so when the light switch is 0 or auto , you have AE always on ( which takes the power from the high beam DRL setup ) , when light switch is at 1 ( parking light ) the AE will be powered by 2 sources ( high beam - OEM AE ) and that's why we need to use one way diodes , but anyway AE stays on ,, and when light switch is at 2 ( low beam ) , the AE will get power only from the OEM AE wire ,
only one scenario the AE will be switched off : is when the light switch is on 0/Auto and you hit the high beam ,, the bixenon will kick in and AE goes off , once the high beam is switched off , AE is ON again ,,
Old 02-22-2011, 11:07 PM
  #386
Ehssan's Avatar
My Ride: Many BMW's
sounds like you were hungry ( if you are kinda fat like me ) when you posted this loool ,,
you were not focusing at all at my class ,,
Old 02-23-2011, 08:16 AM
  #387
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Lol.
I think the confusion stemmed from me not being able to remember if the "parking light" is on when the low beams are on. From what it sounds it, it is lit, so at night time, with the switch set to Auto, it should still turn the AE's on.
However, like I mentioned above, going through this method, you effectively get a empty hole in the space where your high beam bulbs used to be.
Old 02-24-2011, 06:10 AM
  #388
d4rkchocolate's Avatar
yeah sure, just load up SSS Progman, and its in the CKM climate section, turn memory OFF to active, and thats it everytime u get into the car it remembers your last setting..... do the same with the Aircon aswell with the auto, that is truely annoying
Old 02-24-2011, 10:45 AM
  #389
Ehssan's Avatar
My Ride: Many BMW's
I don't have the SSS program working yet on my computer ,,I know there is a lot of options over there including auto mirror folding and light sensor options etc ,,, thanks for your reply dude ,,, I thought there is something in NCSexpert ,,, what a lazy me
Old 02-24-2011, 11:56 PM
  #390
leceur's Avatar
Been reading up about the NCS Expert programming and I have programmed the MP3 function in my 2006 E61. It wouldn't read MP3 cd's in the top cd player and now it does. During programming I did get the following error:
Code:
ERROR! Modul: COAPI.CPP, Proc: coapiGetAbsPathInfo, LineNr: 01, ErrorNr: 1000
COAPI-1000: error
ERROR! Modul: LFCDHDIA.CPP (A_E60CAP.IPS/IPO), Proc: CDHapiResultText, LineNr: 01, ErrorNr: 2000
COAPI-2000: EDIABAS or SGBD error
SYS-0020: BASE OBJECT FILE NOT FOUND
>> ERROR! Modul: COAPI2.CPP, Proc: coapiRunCabd, LineNr: 06, ErrorNr: 2000
SG_CODIEREN
The Batterie warning light came on also..... I started the car and the OBD indicator came on and the car is now very sluggish. It hardly reacts to the throttle and kick down.
Here's also the fsw_psw.man file I used:
Code:
K931D_ZV_ALLE_TUEREN
	par_frei
K931D_ZV_SELEKTIV
	par_frei
K930E_ZV_VER_N_XMIN_FB
	fkt_frei
K9901_WARNBLINKEN
	par_gesperrt
K9323_ZV_VER_AB_X_KM/H
	fkt_frei
K8129_ZWAKO_AC_EIN_AUTO
	fkt_gesperrt
K7504_HEIMLEUCHTEN_AUS
	par_frei
K7504_HEIMLEUCHTEN_40S
	par_frei
K7504_HEIMLEUCHTEN_90S
	par_frei
K7504_HEIMLEUCHTEN_150S
	par_frei
K7504_HEIMLEUCHTEN_240S
	par_frei
K4328_BLINKEN_TIPPBET
	fkt_frei
K5303_GAL_SEHR_STARK
	par_frei
K8116_KLAPPENAUTOMATIK
	fkt_gesperrt
K5303_GAL_STARK
	par_frei
K5303_GAL_MITTEL
	par_frei
K5303_GAL_GERING
	par_frei
K5303_GAL_SEHR_GERING
	par_frei
K5303_GAL_KEINE_ANHEB
	par_frei
K5305_KLANG_BASS
	par_frei
K5305_KLANG_TREBLE
	par_frei
K5305_KLANG_BALANCE
	par_frei
K5305_KLANG_FADER
	par_frei
K5305_KLANG_REVERB
	par_frei
K5305_KLANG_EQULIZER
	par_frei
K531A_LAUTST_NAV
	par_frei
K531A_LAUTST_VERKEHR
	par_frei
K531A_LAUTST_TELEFON
	par_frei
K531A_LAUTST_SVS
	par_frei
K531A_LAUTST_PDC
	par_frei
K4310_ANZ_SPRACHE_1
	par_frei
K4310_ANZ_SPRACHE_2
	par_frei
K4310_ANZ_SPRACHE_3
	par_frei
K4110_VERBR_L/100KM
	par_frei
K4110_VERBR_MPG_US
	par_frei
K4110_VERBR_MPG_UK
	par_frei
K4110_VERBR_KM/L
	par_frei
K410D_EINHEITEN_WEG
	fkt_frei
K4113_ZEIT_STD_DARST
	fkt_frei
K4116_EINH_TEMPERATUR
	fkt_frei
K9901_UMLUFT_EIN
	par_frei
K9901_NAV_LETZER_HINWEIS
	par_frei
K9901_KOMFORT_PARKBREMSE
	par_frei
K9901_MUTE_EIN
	par_frei
K9901_MONITOR_EIN
	par_frei
K9901_LENKRADHEIZUNG
	par_frei
K9901_RADIO/TELEFON
	par_frei
K9901_SWR
	par_gesperrt
K430C_DATUM_FORMAT
	fkt_frei
C750A_SCHWELLWERT_EMPFIN
	par_gesperrt
C750A_SCHWELLWERT_NORMAL
	par_gesperrt
C750A_SCHWELLWERT_SEHR_E
	par_gesperrt
DRUCK_EINHEIT
	bar
K8601_SOLLWERT_M3
	par_gesperrt
K8601_SOLLWERT_M2
	par_gesperrt
K8601_SOLLWERT_M1
	par_gesperrt
K8601_SOLLWERT_0
	par_gesperrt
K8601_SOLLWERT_P1
	par_gesperrt
K8601_SOLLWERT_P2
	par_gesperrt
K8601_SOLLWERT_P3
	par_gesperrt
K4D01_OFF_CID_DISPL_HELL
	fkt_frei
K4119_DRUCK_BAR
	par_frei
K4119_DRUCK_PSI
	par_frei
K4119_DRUCK_KPA
	par_frei
K8313_GEBLAESE_M10
	par_gesperrt
K8313_GEBLAESE_0
	par_gesperrt
K8313_GEBLAESE_P10
	par_gesperrt
K9901_HUPE
	par_gesperrt
C940C_QUITT_OPT_ENTSCH
	fkt_gesperrt
C940D_QUITT_OPT_SCHAERF
	fkt_gesperrt
C940A_QUITT_OPT_ENTSCH
	fkt_frei
C9419_QUITT_OPT_KLAPPE
	fkt_frei
C9410_QUITT_OPT_SCHAERF
	fkt_frei
C941C_QUITT_AKUST_KLAPPE
	fkt_gesperrt
K9416_QUITT_AKUST_ENTSCH
	fkt_gesperrt
C9413_QUITT_AKUST_SCHAERF
	fkt_gesperrt
K8119_PRG_AUTOMATIK
	par_gesperrt
K8119_PRG_LUFTVERTEILUNG
	par_gesperrt
K8127_KLAPPENPROGRAMM_BO
	fkt_frei
K8119_PRG_GEBL_AKTUELL
	par_gesperrt
K8119_PRG_SCHICHTUNG
	par_gesperrt
K8119_PRG_AC
	par_gesperrt
K8125_KLAPPENPROGRAMM_BO
	fkt_frei
K532F_SENDERLISTE_AUDIO
	fkt_frei
K4D01_OFF_HUD_DISPL_HELL
	fkt_gesperrt
K4D03_ANZEIGE_GESCHWNDGKT
	par_gesperrt
K4D03_ANZEIGE_CHECKCONTRL
	par_gesperrt
K4D03_ANZEIGE_ACC
	par_gesperrt
K4D03_ANZEIGE_TEMPOMAT
	par_gesperrt
K4D03_ANZEIGE_NAVIGATION
	par_gesperrt
K2407_PDC_MONITORBILD
	fkt_frei
CA107_AUT_VERST_DEAKT
	par_gesperrt
CA107_AUT_VERST_ENTR
	par_gesperrt
CA107_AUT_VERST_ENT_T
	par_gesperrt
C9C03_KLAPPENWINKEL
	fkt_frei
C9C01_HKL_TASTE
	fkt_frei
K931D_SCHEIBENABSENKUNG
	par_gesperrt
NIVI
	nicht_aktiv
CDC
	nicht_aktiv
MMC
	nicht_aktiv
AUDIO_SYSTEM
	e60_stereo
	pl2_stereo
	e70_stereo
	pl3_stereo
SVS
	nicht_aktiv
NOTEPAD
	nicht_aktiv
SDARS
	nicht_aktiv
BMW_ASSIST
	nicht_aktiv
HELPNET
	nicht_aktiv
PDC
	aktiv
HUD
	nicht_aktiv
ELDRVSEAT
	nicht_aktiv
MFL_HORN
	nicht_aktiv
MFL_HAZARD
	nicht_aktiv
MFL_CLEAN
	nicht_aktiv
FOND_HIGH
	nicht_aktiv
FOND_LOW
	nicht_aktiv
LAENDERVARIANTE_TUNER
	ece
TP_FUNKTION
	tp
TP
	aktiv
TMC
	aktiv
AMBANDS
	aktiv
BAUREIHE
	e60
	e63
	e64
	e61
BAUART
	touring
CODIERUNG_ERFOLGT
	codierung_erfolgt
TWO_MICROPHONES
	wert_01
TYP_LENKUNG
	linkslenker
ACC
	nicht_aktiv
WAEHLBARE_SPRACHE_1
	niederlande
WAEHLBARE_SPRACHE_2
	englisch
WAEHLBARE_SPRACHE_3
	franzoesisch
ADRBOOK
	aktiv
WEG_EINHEIT
	km
AEREA_CODE_DVD
	wert_02
DWS
	aktiv
BMW_N_DEALER
	aktiv
TRF
	nicht_aktiv
KANA_WRITER
	nicht_aktiv
SMS
	nicht_aktiv
WEATHERBAND
	nicht_aktiv
LEGAL_DISCL
	nicht_aktiv
REV_INPUT
	nicht_aktiv
UNIT_FEET
	nicht_aktiv
ACOUSTIC
	nicht_aktiv
TEMPERATUR_EINHEIT
	grad_c
ZEIT_EINHEIT
	24_stunden
DATUM_EINHEIT
	tt_mm_jj
NAVIGATION
	aktiv
BACKDOOR
	nicht_aktiv
STANDHEIZUNG
	nicht_aktiv
DIGITAL_AUDIO_SOURCE
	cd-player
PHONE_VERSION
	no-phone
BA_LAENDER_VARIANTE
	wert_01
DEF_DATUM_EINHEIT
	tt_mm_jj
DEF_DRUCK_EINHEIT
	bar
DEF_TEMPERATUR_EINHEIT
	grad_c
DEF_WEG_EINHEIT
	km
DEF_ZEIT_EINHEIT
	24_stunden
JAPAN
	nicht_aktiv
MULTIPARTY
	nicht_aktiv
NAVIGATION_TYPE
	navi_sv
ONLINE
	nicht_aktiv
ONLINE_DISABLE_CONTENT
	content_enable
ONLINE_DISABLE_VMAX
	standard
REVERSE_GONG
	nicht_aktiv
SIM
	nicht_aktiv
SPRECHER_AKTIVE_SPRACHE
	sprecher_weiblich
SPRECHER_ALTERNATIVE_2
	sprecher_weiblich
SPRECHER_ALTERNATIVE_3
	sprecher_weiblich
DEF_BALANCE_VOLUME
	standard
DEF_BASS_VOLUME
	standard
DEF_ENTERTAIN_VOL
	standard
DEF_EQUALIZER_VALUE
	standard
DEF_FADER_VOLUME
	standard
DEF_GAL_VALUE
	keine_anhebung
DEF_GONG_VOLUME
	e60_stereo
	e60_hifi
	e63_hifi
	e61_stereo
	e61_hifi
	e64_hifi
	e87_stereo
	r56_stereo
DEF_JPGONG_VOL
	e60_stereo
	e60_hifi
	e63_hifi
	e61_stereo
	e61_hifi
	e64_hifi
	e87_stereo
	r56_stereo
DEF_LAST_SPEECH
	niederlande
DEF_NAVI_VOLUME
	standard
DEF_PDC_VOLUME
	e60_stereo
	e61_stereo
	e87_stereo
	r56_stereo
DEF_REVERB_VALUE
	standard
DEF_SEC_VOLUME
	standard
DEF_SPEECH_VOLUME
	standard
DEF_TEL_VOLUME
	standard
DEF_TM_VOLUME
	standard
DEF_TREMBLE_VOLUME
	standard
GAL_VALUE
	keine_anhebung
LAST_BALANCE_VOLUME
	standard
LAST_BASS_VOLUME
	standard
LAST_ENTERTAIN_VOL
	standard
LAST_EQUALIZER_VALUE
	standard
LAST_FADER_VOLUME
	standard
LAST_GONG_VOLUME
	e60_stereo
	e60_hifi
	e63_hifi
	e61_stereo
	e61_hifi
	e64_hifi
	e87_stereo
	r56_stereo
LAST_JPGONG_VOL
	e60_stereo
	e60_hifi
	e63_hifi
	e61_stereo
	e61_hifi
	e64_hifi
	e87_stereo
	r56_stereo
LAST_PDC_VOLUME
	e60_stereo
	e61_stereo
	e87_stereo
	r56_stereo
LAST_REVERB_VALUE
	standard
LAST_SEC_VOLUME
	standard
LAST_SPEECH
	niederlande
LAST_SPEECH_VOLUME
	standard
LAST_TREMBLE_VOLUME
	standard
EINH_MASTER_KOMBI
	nicht_aktiv
ONLINE_CALLSTRATEGY
	use_csd_paketdata
CRUISE_CTRL_CCC
	nicht_aktiv
OIL_LEVEL
	aktiv
CBS
	cbs_3
CID_CCC
	cid_high
CID_COLOUR
	table_1
CID_TYPE
	static
KLIMA_SG_ART_CCC
	high
PDC_SIGNAL
	pdc_no
PDC_TYPE
	full
PIA
	ckm
VA_FLAP_CC
	nicht_aktiv
VA_FLAP_DISPLAY_CONFIG
	nicht_aktiv
VA_FLAP_HMISTART
	nicht_aktiv
VA_FLAP_NAVI
	nicht_aktiv
VA_FLAP_PHONE
	nicht_aktiv
VA_FLAP_SVS
	nicht_aktiv
RDC_CCC
	nicht_aktiv
AUTO_DRV_LIGHT
	nicht_aktiv
C7501_TAGFAHRLICHT
	fkt_frei
HDC
	nicht_aktiv
RAIN_LIGHT_SENSOR
	nicht_aktiv
STANDLUEFTUNG_CCC
	aktiv
MDRIVE
	nicht_aktiv
MDRIVE_ALBV
	nicht_aktiv
MDRIVE_SMG
	aktiv
BLUETOOTH_NODES_CCC
	profil_2
HUD_M
	nicht_aktiv
MAX_PHONE_VOL
	standard
	e60_stereo
	e60_hifi
	e60_top_hifi
	e61_stereo
	e61_hifi
	e61_top_hifi
	e63_stereo
	e63_hifi
	e63_top_hifi
	e64_stereo
	e64_hifi
	e64_top_hifi
	e87_stereo
	e87_hifi
	e87_top_hifi
	r56_stereo
	r56_hifi
	e90_stereo
	e90_hifi
	e90_top_hifi
	e91_stereo
	e91_hifi
	e91_top_hifi
	e92_stereo
	e92_hifi
	e92_top_hifi
MFL_MENU
	nicht_aktiv
AUX_CONFIG
	not_mounted
VA_BPI
	nicht_aktiv
HIP
	aktiv
RDS_AF_FUNKTION_CCC
	rds_ein_af_automatisch
MP3_CCC
	full
IBOC_CCC
	nicht_aktiv
NIVI_DISPLAY_OPTIONS
	main_or_fullscreen
RVC
	nicht_aktiv
RVC_CONNECTED_TO_VM
	nicht_aktiv
RVC_DISPLAY_OPTIONS
	main_or_fullscreen
TOWBAR
	nicht_aktiv
SVS_MICROPHONE_PATH
	analog
ALLOW_GPS
	aktiv
BMW_DEALER_CCC
	aktiv
BMW_HOTLINE_CCC
	nicht_aktiv
BMW_MOBILE_CCC
	aktiv
DAY_RUN_LIGHT_CCC
	aktiv
DSC
	nicht_aktiv
ROLLER_COVER
	nicht_aktiv
ZBE
	high
DAB
	nicht_aktiv
DAB_BAND_SETTINGS
	nicht_aktiv
DAB_FM_SWITCH
	nicht_aktiv
REAR_HEAD_UNIT
	nicht_aktiv
VA_MP3_DISCLAIMER
	nicht_aktiv
FOND_MID
	nicht_aktiv
CA_TMC
	nicht_aktiv
JAP_SIDEVIEW_CAM
	nicht_aktiv
LEGAL_DISCL_TIMOUT
	standard
TOP_AMPL_TYPE
	nicht_aktiv
VA_ADAPTIVEHEADLIGHT
	nicht_aktiv
VA_CORNERINGLIGHT
	nicht_aktiv
VA_FB
	nicht_aktiv
VA_FB_COMMUNICATION
	nicht_aktiv
VA_FB_ENTERTAINMENT
	nicht_aktiv
VA_FB_NAVIGATION
	nicht_aktiv
VA_FM_AM_TOGGLE
	nicht_aktiv
VA_FOND_CLIMATE
	nicht_aktiv
VA_LONGDISTANCELIGHT
	nicht_aktiv
VA_MANUAL_SHIFT
	nicht_aktiv
VA_MODE_TOGGLE
	nicht_aktiv
VA_NOAIRVENT_FINETUNING
	nicht_aktiv
VA_SEATVENTILATION
	nicht_aktiv
VA_WELCOMELIGHT
	nicht_aktiv
CAR_COLOR_CHAMP
	nicht_aktiv
TELEFON_TYPE_C08
	mulf_phone
VA_AIRVENT_SHORTCUT
	nicht_aktiv
VA_AUTOMATIC_SHORTCUT
	nicht_aktiv
VA_PDC_LOW
	nicht_aktiv
VA_SEATCLIMA_SHORTCUT
	nicht_aktiv
VA_SEATHEAT_SLIDER
	nicht_aktiv
DVD_EJECT_LOCKED
	free
AUDIO_VOLUME_STEPS
	e60_stereo
	e61_stereo
	e87_stereo
	e90_stereo
	e91_stereo
	e81_stereo
FULLWORD_RECOG
	aktiv
CC_LIST
	aktiv
DKG
	nicht_aktiv
EDC
	nicht_aktiv
CBS_STATUS
	aktiv
CLIMATE_WO_PREVIEW
	nicht_aktiv
NO_DETOUR
	nicht_aktiv
ALBV_TOGGLE_APP
	nicht_aktiv
BGSCREEN_JUMP
	aktiv
DAB_FROM_FM
	wert_01
DAB_TO_FM
	wert_01
MEDIA_CHAR_ENCODING
	iso
MM_DEVICE
	nicht_aktiv
MM_DEVICE2
	nicht_aktiv
NEXT_SOURCE
	nicht_aktiv
OLD_TELEMAT_STRUCT
	aktiv
TLC
	nicht_aktiv
VA_HANGUL_TYPEWRITER
	nicht_aktiv
VA_KANJI_TYPEWRITER
	nicht_aktiv
TDA_ASC_STATUS
	nicht_aktiv
TDA_BDA_STATUS
	nicht_aktiv
TDA_CFG_AUTO_TRIG
	nicht_aktiv
TDA_CFG_CUST_MOBILE_USE
	aktiv
TDA_CFG_HLC_DATA
	nicht_aktiv
TDA_CFG_IND_PDM_GR_NBR
	file0
TDA_CFG_SER_ERR_SINK
	aktiv
TDA_CFG_VEHICLE_SER
	nicht_aktiv
TDA_DEACTIVATE_STATUS
	aktiv
TDA_HLC_STATUS
	nicht_aktiv
TDA_MSC_STATUS
	nicht_aktiv
TDA_SERVICE_STATUS
	nicht_aktiv
TDA_TDC_STATUS
	nicht_aktiv
MDRIVE_LOW_CCC
	nicht_aktiv
SITZHEIZUNG_APP_9
	nicht_aktiv
CCC_E71
	nicht_aktiv
NAVI_PFEIL
	aktiv
TELESERVICE
	nicht_aktiv
MDRIVE_MENU
	nicht_aktiv
RSEMIDPLUS_AVAILABLE
	nicht_aktiv
SVR
	nicht_aktiv
TV_FRONT_ENABLED
	nicht_aktiv
VEHICLE_FINDER
	nicht_aktiv
VIDEO_DENY_C0B
	deny_slow_key
ONLINE_DAR_TYPE_B
	dar_ece
VIDEOMODUL_CCC_B
	nicht_aktiv
DEF_VERBRAUCH_CCC
	l/100km
TMC_REGIONAL_C
	nicht_aktiv
VERBRAUCH_CCC
	km/l
Any tips/help is GREATLY appreciated!
Quick Reply: Car Coding
