Car Coding
Old 02-09-2011, 10:50 AM
  #341
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
I checked it through NCS Dummy as well. Is it pretty safe to say that it's always correct as it's reading and outputting possible factory values?
That being the case, I guess this is a different entry than for us E60 guys.
Old 02-09-2011, 02:34 PM
  #342
Chazaxl's Avatar
Quick question - if I invest in the tools listed in this thread, apart from being able to set options, will I have the ability to 'update' the various firmware / software(s) for the car like for example a newer version of software that improves the automatic box's jerky behaviour etc?
Thanks
Old 02-09-2011, 08:44 PM
  #343
Ehssan's Avatar
My Ride: Many BMW's
i'm not sure if NCSdummy is 100% accurate but so far it always give me all the values available in the trc files , NCSdummy reads all the information and possible values from the daten files in the NCS folder , so I'm really confident with the results and sometimes you might bwe lucky to get some translation as well , it will take you less than a minute to read any trc file on NCSdummy but you really need to make sure you choose the right module model .
so basically either we can't have the double hazard on our E60's or the double hazard is in different code ..let's keep looking around
Old 02-09-2011, 11:19 PM
  #344
BLooD's Avatar
Thanks
Yes you can but over the OBD port some modules can take hours to program so you will need a good quality battery charger with at least 20amps at 14v.
Old 02-09-2011, 11:25 PM
  #345
Chazaxl's Avatar
Thanks - is there a proper list of the available modules? How do the dealerships do the changes if not via the ODB port? Is what I think is called Progman 'freely' available?
Old 02-09-2011, 11:30 PM
  #346
BLooD's Avatar
In the glove box is a closed port in the fibre optic data line, they open the port and connect a high speed data connector to it and flash program the modules from there. Progman is and has been floating around the net for a long time, when you get to 10 posts PM me and I will sort you out with every thing you need, you will need to get a D-can INPA/ediabas OBD2 usb cable and have a half decent laptop available.
Old 02-09-2011, 11:40 PM
  #347
Chazaxl's Avatar
Thanks. At present my local indy that I use want I think around £65 to do an update for me which address the gearbox's gear changes etc. It seems that the cable alone will cost that - then again, if its a longer term thing I dont mind paying a bit more so that I can play.
Do you know if the module for the gearbox requires me to have a battery charger? Is there a list of available modules that can be flashed and what the latest versions are?
Thanks
Old 02-09-2011, 11:58 PM
  #348
BLooD's Avatar
Dont matter if the module is big or small, dont flash any module with out a battery charger its as simple as that, if your battery goes flat and the car goes into emergency shut down thats the module down the toilet.
There isnt a definite list as it depends on the options fitted, as for the latest software that could be ISTA/p v42, progman is no longer used by the service centers. I have v40.
Old 02-10-2011, 10:22 AM
  #349
Chazaxl's Avatar
Thanks. I checked my version with the idrive button 'trick' and it doesnt show a CIP number as I suspected from another thread but many modules for the various options (car is 545i SE with almost all options) but at the bottom was what I believe the be one of the main modules:-
E60 - something - need to check my phone for the image ...
Old 02-10-2011, 10:44 AM
  #350
Chazaxl's Avatar
At the top of the menu:-
Build Mar 26 2004 c: h:5.21.5
The last info in the menu at the bottom:-
E60 I-06-04-500 PL2 I-4-45 MASK MMI T
Does this mean anything?
Quick Reply: Car Coding
