Car Coding
#241
Location: Calgary, AB - Canada / Buenos Aires - Argentina
My Ride: 2006 BMW M5
Look under /WORK folder the file called FA.TRC it will tell you what FAs/VOs are installed on your car.
If DWAS in which is (S6UEA or $6UE) or (S302A or $302) is missing, then your car does not have it.
If you have it, then make sure you clear all in FSW_PSW.MAN (don't delete the file) and try it again.
#242
My Ride: Many BMW's
how can I read the .trc for the whole car ,, I see the guys does trc file for all the modules of the car in one file ..
#243
I do have $302 , I did clear .MAN file but still getting the same error ...
... anyways not that important ,,i wanted to have the Beep when lock /unlock the car ....
Does someone knows what do i have to have in FAs/VOs for having welcome light ?
#244
My Ride: Many BMW's
After you hit BACK on NCS go to WORK folder and in FSW_PSW.TRC you will have all the car. Usually it has 213 k, but it is not a rule. Mine for exampling after i play around with some coding, now has 222 k and i don't know why.
#245
guys , I've noticed something now ,, before I activate flash to pass bixenon option , my high beam used to stay like 1 second when I hit the high beam stick , 1 second is too much ,, and ppl gets angry considering it bad attitude .. after i activate the flash to pass bixenon in LMA , now even my bixenon stays for 1 second , so it's not flash anymore ...
tried to look at the LMA trc file maybe i find something in it ,, but i didn't understand it . for sure it's an option with different values not something like not active/active ...
guys with LCI headlights or guys with 2006/2005 ,,, if you don't have this issue with your high beam ... could you please post me your lma trc file so that I can compare it with mine and see if i can find that option to reduce the time of high beam ... because I remember in my previous 2006( 11/05 ) didn't have this problem ,, the high beam was really fast and it last for less than 1/2 second ... also in my E92 335I is the same ..the bixenon flash is really quick ....
thanks
thanks
My rid is 530 2004 (04/03)with adaptive xenon
See the attached file my car original LMA TRC file
#247
Ehssan, better compare between M5s
2006 M5 (Prod. Nov - 2005)
Here is my LMA (24kb)- original
FSW_PSW.TRC.lma.txt
I would like to get your LMA trc too.
thanks,
FSW_PSW.TRC.lma.txt
thanks,
#248
My Ride: Many BMW's
Attachment 116857
thanks,
Attachment 116857
thanks,
i'll have a look at yours ,, thanks ,, attached is my original one before any changes ...
#249
Model Year: 2005
Engine: 545i
So as posted in the parts subforum HERE - audible alarm when ulocking/locking was activated simply by setting
CAPPL
ACOUSTIC
activ
I did NOT need to modify the following in my case:
C941C_QUITT_AKUST_KLAPPE
fkt_gesperrt -> fkt_frei
K9416_QUITT_AKUST_ENTSCH
C9413_QUITT_AKUST_SCHAERF
fkt_gesperrt -> fkt_frei<BR style="mso-special-character: line-break"><BR style="mso-special-character: line-break">modifying them on mine returned a coding error, I only needed to set ACOUSTIC to activ.
trace file for CAPPL and DWAI and DWAS:
FSW_PSW.TRC.CAPPL.txt
FSW_PSW.TRC.DWAI.txt
FSW_PSW.TRC.DWAS.txt
can I suggest we add relevant module trc files whenever we do successful coding to enable others to see setting and compare (with NCS Dummy)
CAPPL
ACOUSTIC
activ
