Car Coding
#161
Hi Everyone,
I have installed the new CIC/CID to my 2004 545I (with Premium Audio). But now there is no audio (maybe because the donor car did not have that option). And once I put an audio CD in the drive, it is not coming out.
So I need to program CIC for my VO. Does anyone know how do I do that with NCS Expert?
After I added $6VA to VO in CAS, I can see CIC as an available ECU when I select Change ECU button.
But I have problem coding the VO to CIC. There is no FA_WRITE option for CIC. I tried SG_CODIEREN option but it is erroring out.
Another problem I have is I can not code LMA module with FA_WRITE option. It is failing with some message in German (Error number 14?). I am not sure why I am able to code CAS but not LMA.
Can antone point me to right direction? I have NCS Expert v3.1.0 and the Daten files which has imformation upto 0310.
Thanks,
Bhavi
Thanks,
Bhavi
#162
Hi Everyone,
Thanks,
Bhavi
Thanks,
Bhavi
FA_WRITE is for adding new FA numbers to the VO in the CAS and LMA.
#163
My Ride: M3
Model Year: 2017
Hi Everyone,
Thanks,
Bhavi
Thanks,
Bhavi
#164
#165
And this is after you changed the production date of your car?
#166
#168
it seems like your dataen files may be older than what is already loaded on the CIC. Also what version of NCS are you using.
#169
Also The Daten Files under C:\NCSEXPER\DATEN\E60 are dated Jan 8, 2010. So daten files are about a year older.
Do you have latest daten files available for E60?
