Car Coding
#141
Engine: N54
BMW Coding options done via NCSExpert. Include better notes on what the option does than the german translations that are in other threads.
Include things you tested or things you specifically tried and note that it didn't work or what to expect.
After a few edits maybe we can put the tested stuff in it own thread and keep this one for the usual testing type discussions.
CAPPL:
LEGAL_DISCL (No legal notice on IDrive startup)
nicht_aktiv
VA_WELCOMELIGHT (Welcome lights menu in iDrive. Requires change in LMA module also)
aktiv
ONLINE (Enables BMW Onine in Communications iDrive screen- Works in UK? not in USA?)
aktiv
SIM (Activate SIM for internet svc - no "GSM" service message for USA)
aktiv
VA_CORNERINGLIGHT (Cornering lights menu. Lights come at low speed turns, with turn signals and in reverse.)
aktiv
VA_SEATCLIMA_SHORTCUT (Seat heater display comes up in iDrive when heat button pushed)
aktiv
VA_SEATHEAT_SLIDER (Seat heat hi-med-low slider in iDrive)
aktiv
VA_LONGDISTANCELIGHT (Shows Highbeam assistant menu option. (must have the hardware too for it to do anything)
aktiv
VA_ADAPTIVEHEADLIGHT (Adaptive headligh menu with Comfort and Sport options. Don't know what they do. Have not tested)
aktiv
LMA:
WELCOME_LIGHT_Active (Welcome lights menu in iDrive. Requires light switch in auto position)
aktiv
WL_DAUER (Does this make welcome lights stay on longer ?? )
wert_02
WL_NSW (Fog lamps with Welcome lights)
soft_einschalten
FL_UND_NSW_NICHT_GLEICHZ (Allow High beam and fog lamps on at same time)
active
KOMBI:
BC_DIGITAL_V (digital speedometer is cluster)
aktiv
SHD:
REGENSCHLIESSEN (close sunroof with auto wipers and rain - doesn't work ???)
aktiv
CAS:
KOMFORTSCHLIESSUNG_FB (Close windows via key FO
aktiv
IHKA:
GEBL_ANZEIGE_AUTO (Climate fan speed display via orange light around manual speed knob)
active
HUD:
BLINKER_AUSSTATTUNG (turn signals in HUD)
aktiv
CAPPL:
nicht_aktiv
aktiv
aktiv
aktiv
aktiv
aktiv
aktiv
aktiv
aktiv
LMA:
aktiv
wert_02
soft_einschalten
active
KOMBI:
aktiv
SHD:
aktiv
CAS:
aktiv
IHKA:
active
HUD:
aktiv
#142
Cornerlights also come on if you do a sharp turn to add extra illumination.
Beiklappen_b_komfortschl KGM from sept 2005 confort folding mirrors
ASP_BORDSTEIN KGM from sept 2005 passenger mirror kerbfunction (memory seats not needed)
#144
Engine: N54
#145
if you have xenons in your car, chances are that it may be bi-xenons, and what i found on my 5, and my mates 6 series, is that the flash to pass option (especially on the Pre-LCi)
would flash the inner halagen ones instead of the main xenon lights. the aforementioned code i found, tells the car to use the bi-xenon to flash to pass when you pull the stalk back...
#146
Engine: N54
Got it. That sounds familiar. Something about the xenons being too slow to flash so the halagens were used. I'll give it a test.
#147
Engine: N54
Anyone know how to code the Angel Eyes as DRL's?
#148
#149
My Ride: 2007 E60 535d M Sport
#150
