Brake fluid change DIY
Old May 16, 2010 | 07:42 PM
  #61
ktlocklear's Avatar
My Ride: '06 550i '84 Nissan S12 Turbo
Will one 1 liter can of the ATE blue be enough to bleed and fill the MC with?
Old May 16, 2010 | 11:27 PM
  #62
spinitch's Avatar
My Ride: 2005 530i Premium Package
Yup, 1 liter will do the job.
Old May 17, 2010 | 05:52 AM
  #63
ktlocklear's Avatar
Awsome..thanks. Oh, may be moving back to Sac sooner than later
Old Jul 30, 2010 | 10:52 PM
  #64
stock545i's Avatar
My Ride: 545i, Adaptive Xenons, 19" 166's
Great DIY!
Old Aug 3, 2010 | 01:58 PM
  #65
salaki's Avatar
My Ride: 05 545i 6MT
Motive's BMW bleeder cap fits exactly on 5 series (bolt on)
The Japanese "generic" cap doesn't bolt on to any specific application.
You have to wrap chain from the cap and around the reservoir.
It's pretty easy if the brake fluid reservoir if exposed, if not, it's pretty sucks to seal the reservoir w/ generic cap to apply pressure.
Old Aug 31, 2010 | 05:16 AM
  #66
Georgieb's Avatar
My Ride: 2007 Black Sapphire 535i
Great info guys. My brake fluid alert just came on a few days ago also. I was dreading the dealer visit. Now I have a way forward.
Thanks!
Old Feb 27, 2011 | 01:07 PM
  #67
stevej30's Avatar
beaker
Thanks for taking the time for documenting this procedure. Saves time and adds confidence
in doing it yourself.
stevej30
Old Mar 12, 2011 | 12:51 PM
  #68
jay77's Avatar
Great guide Beaker the Sealey VS820 - Brake bleeder works fine too!
Old Apr 19, 2011 | 04:30 PM
  #69
itb76's Avatar
My Ride: 2004 545i,1995 M3
Originally Posted by zen
...As a final thought, I personally think it is a bunch of BS regarding the necessity of changing the fluid unless you have a race car. Name any other manufacturer that has this requirement and don't say that BMW's are something special. In my case the dealer didn't do it on my car and I have a hunch it may just be a scam...
Every German branded car I ever owned had brake fluid replacement as required service. I've had VW, Mercedes, and now BMW. I don't believe the Japanese or US cars had. Must be the German mindset, but as a racer I agree it's important. Brake fluid absorbs moisture, and thus old brake fluid has a lower boiling point than new, and will also lead to rust inside the braking system. The way I drive, regular brake fluid replacement is worth it.
Originally Posted by chrislinney
would there be any problem in doing this by just opening the bleed on the caliper (tube attached of course ) and letting gravity do the trick ? , as i have done on my previous cars , making sure the resevoir never gets empty ?
Tilton used to sell a kit to do just that; maybe they still do. I could never make it work without pumping the pedal a few times after connecting the bottle and opening the bleeder screw. After a few pumps more fluid would come out, either by gravity or momentum, not sure which. Took a long time though, and if the threads around the bleeder screw were loose air could get into the caliper through the threads.
The old two man method is probably still the best, though the pressure bleeder should be more convenient. I have heard people say the pressure bleeders force moisture from the air into the fluid, but if you change the fluid every two years I would think that's not a concern.
Old Apr 21, 2011 | 04:10 AM
  #70
lcc014's Avatar
My Ride: E60 530i
Engine: M54
I agree with the 2 old men method. For me, it was 1 old mand and 1 old woman
