Brake fluid change DIY
Old Apr 30, 2010 | 06:46 AM
  #51
latitude39's Avatar
My Ride: 2007 530xi (N52 6-cylinder engine)2002 325xi (M54 6-cylinder engine)2008 Specialized Roubaix road bike
Thanks for the great writeup and superb photos. I just completed the job on my wife's 2007 530xi.
This is about my cross-threading experience--a cautionary tale.
My experience varied from the writeup only where my Motive pressure tank screwed onto the plastic-threaded reservoir. The red, machined aluminum cap screwed on and held pressure with only minimal hand tightening--but only after 2 prior attempts to pressurize the system with a cross-threaded cap. The sharply machined aluminum threads will find a purchase in the relatively soft plastic if you're not careful. When the threads mate correctly, you'll get 3 or 4 satisfying turns of the cap--and the system will hold pressure. I found no need to wrench the cap on once I got the threads lined up. In fact I think with too much torque you could easily destroy the plastic tank.
FYI: I chose to use the pressure tank without filling it with brake fluid--air pressure only. That did make cleanup a cinch. I had to de-pressurized/re-pressurize between my 3 fillings of the reservoir. Just watch the fluid level. Keep it above "MIN". I used most of 1 quart(litre?) of Castrol synthetic DOT 4 fluid.
Old May 1, 2010 | 04:24 PM
  #52
bimmerluuvr's Avatar
My Ride: 06' 530 Alpine/Auburn/Dark walnut, Sport, Premium, Sirius, 35% Tint Upcomming mods: M166's/Exclaim UHP's, Mtech
Anybody know if the Bavauto bleeder will accept different caps for the MC? I have two japanese cars that I would like to use it on. Or are there other bleeders out there that I can use on my 5er AND my other cars? ONLY interested in the pressure type bleeders.
Old May 1, 2010 | 04:54 PM
  #53
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
Yes, you can "mod" it to accept the universal adapter from Motive. Just get creative .
Old May 1, 2010 | 07:41 PM
  #54
"Motive"? a company that sells different caps for the MC? Is that the full name of the company, Motive? I'd like to look them up.
Old May 2, 2010 | 12:16 AM
  #55
spinitch's Avatar
My Ride: 2005 530i Premium Package
Got my motive bleeder on ebay. Best prices
Old May 2, 2010 | 12:39 AM
  #56
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
Motive Products 1101 Universal Round Adapter Kit JEGS .
Old May 2, 2010 | 03:12 PM
  #57
So let me make sure I have this: The cap made by JEGS and sold through Motive, will fit the pressure bleeder by BavAuto, and will fit the MC in my japanese cars properly? I want to be able to use my Bav bleeder on both my bimmer and my Acura and Toyota.
Old May 3, 2010 | 12:40 AM
  #58
spinitch's Avatar
I don't think the motive cap will fit the bavauto ones without modifying it like someone earlier said. It is a motive cap sold by JEGS that fits the motive speed bleeders directly. You would have to make a conversion like Rizbel did, then you can use it fit Japanese cars.
http://cgi.ebay.com/ebaymotors/MOTIV...item3a4a377070
This is all you need. Comes with the motive bleeder, european and japanese import caps for those who are looking for a complete setup.
Old May 3, 2010 | 05:57 AM
  #59
So I can cancel my order to BA if the pressure bleeder from Motive comes with caps for both my bimmer and my japanese cars. I can use this one for both cars, a complete setup is correct,
Old May 3, 2010 | 12:56 PM
  #60
spinitch's Avatar
Yup, just order the motive package I linked to. It comes with the European cap and Japanese cap. I've already used them on BMWs, Mercedes, Toyotas..
