AE Illumination when unlocking the car
Old 06-01-2010, 10:43 AM
  #51
johal's Avatar
i am so jealous....im another member from the UK who does not have footwell lights, neither does my brother's or 2 of my cousin's! Its got to be an extra option in the uk! dammit
Old 06-01-2010, 11:27 AM
  #52
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Well not having footwell light is not the end of it. I tapped into the welcoming dome light. The wire is hidden through the pillar and routed to the top, can't even see it.
Old 06-01-2010, 12:56 PM
  #53
schulrog's Avatar
correct. Dome light is possible too but just a little more tricky to get done since you have to remove the A pillar trim to route a wire through
Old 06-01-2010, 01:02 PM
  #54
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Actually not really, it's possible to just tuck it under without removal
Old 06-01-2010, 03:43 PM
  #55
schulrog's Avatar
ohh i see just push the wire in far enough under the trim eh... not a bad idea but to be clean i'd just run it along the existing harness
Old 06-01-2010, 06:30 PM
  #56
antzz_87's Avatar
My Ride: 2004 BMW 530I, K&N CAI, M-tech front bumper, Sprint-booster, Silver Hella taillights (vehicle is under construction)
Hello everyone..
I need another help, anyone here know which of these 3 cables should I tapped to turn on my drl when unlocking the car? I tried using the voltmeter but didnt work on this one, I still cant find the power cable.
Thanks..
Attached Thumbnails AE Illumination when unlocking the car-img00004-20100601-1849.jpg
Old 06-01-2010, 07:37 PM
  #57
antzz_87's Avatar
I forgot to mention that I bought the 18 gauge cable instead of 22 as recommended, will this cause any problem?
Old 06-01-2010, 09:21 PM
  #58
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
Originally Posted by antzz_87
Hello everyone..
Thanks..
The white one is the positive for the DRL(also flash-to-pass) bulb. The brown is ground.
Old 06-01-2010, 10:01 PM
  #59
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
Originally Posted by Hellraiser
The member, which was me did not share because he does not know how it was done!
Because if he did, he would have shared the hole process!
What made you think it was you?
Old 06-02-2010, 08:36 AM
  #60
antzz_87's Avatar
eventhough it was really hard for the first timer, I managed to tapped all the cables needed, now my question is how did you guys add the diode in between the cable? Glue it? Tape it?
Quick Reply: AE Illumination when unlocking the car
