AE Illumination when unlocking the car
#131
#132
don't quite understand what you mean... the AE's and the headlights are seperate. if you only want the AE's to come on you tap into the 12V wire for both AE's. if you want the headlights to come on as well then you'd tap 4 wires. 2 x AE and 2 x headlights.
#134
ohh yeah.. just wire your cig lighter to the fogs and make sure you put a diode in. that should work just fine actually. the fogs will have a short intermittance when you turn on the car bc the voltage level drops but they should come right back on.
this might actually b my next project since i always have the fogs on anyway
#135
Yea i thought it would work as well. I just need to know which wires to tap into for fogs? Does the harness by the headlight also have wiring for the fogs or do i have to go under to tge fogs thenselves?
