Adding speed camera POI to your SatNav DVD
Old Aug 2, 2006 | 06:33 AM
  #141
M3 SMGII's Avatar
My Ride: BMW E60 and F10
do i have to change the CSV.-files to ASC.-files???
thx in advance
Old Aug 2, 2006 | 01:11 PM
  #142
anit999's Avatar
Is anyone selling copys of the comleted satnav DVD with speed camera POI ?
Old Aug 7, 2006 | 01:00 AM
  #143
M3 SMGII's Avatar
can anyone help me??
till step 12 it goes without problems.
But step 13 it doesnt work for me. You have to type tis "c:\cygwin\bin\perl createidxurl.pl pocketgps_uk_sc.asc 9000 (press return)" but mine is not working. always a error
What am i doing wrong?
many thanks
Old Aug 7, 2006 | 01:12 AM
  #144
mathmos's Avatar
Originally Posted by Andy E61' post='317016' date='Jul 30 2006, 10:31 PM
I have followed the detailed instructions on the support website, for which I am VERY grateful, however
although I now have a burned DVD which seems to have all of the relevant files, in the right locations, when inserted into my DVD slot in the car I get no recognition.
I am an experienced PC user but this is the first time that I have used the perl scripts (or similar), so I anticipate some pilot error on my part.
Anyone have any ideas why my DVD+RW with all necessary files isn't recognosed by my 04-2005 E61?
Kind regards
Andy
Which method did you follow, Nero or ISO ?
Old Aug 7, 2006 | 01:18 AM
  #145
mathmos's Avatar
Sorry been away on my hols
I presume you are following the Nero method, correct?
When you test your perl installation with
c:\cygwin\bin\perl -v
does this work correctly?
What error do you get when when you try to run the createidxurl.pl script?
Old Aug 7, 2006 | 01:20 AM
  #146
mathmos's Avatar
thx in advance
The format of the input file the perl script is expecting is
Longitude,Latitide,"description"
so as long as your input file is in this format you should be ok. Note
the description bit does need "" around it like this:
;Longitude,Latitude,Name
-2.17788,50.68304,"GATSO:1@40"
-2.09934,50.70723,"GATSO:2@30"
-2.08936,53.50270,"GATSO:3@20"
-0.11078,52.02661,"GATSO:8@70"
-0.39579,51.52150,"GATSO:10@50"
-2.48386,52.69615,"GATSO:12@30"
-2.07762,53.51140,"GATSO:13@30"
-2.74783,53.32440,"GATSO:14@60"
Hope this helps.
Old Aug 7, 2006 | 01:32 AM
  #147
M3 SMGII's Avatar
yes if i type c:\cygwin\bin\perl -v it works correct.
But then you have to add a file and it says file not found, something like that.
i am using nero yes.
thx
Old Aug 7, 2006 | 06:13 AM
  #148
mathmos's Avatar
thx
and in the command prompt have you changed directory to where the speed camera locations input file is located before executing the command? If not then you will need to do that or change your command line to something like:
c:\cygwin\bin\perl createidxurl.pl c:\<dir holding input file>\pocketgps_uk_sc.asc 9000
Old Aug 7, 2006 | 02:11 PM
  #149
Allymunro's Avatar
My Ride: 525i M Sport Touring (E61): Mystic Blue with Beige Leather and Light Poplar Wood Trim | M Sport Package: Anthracite Headlining, Dechroming, 18" M Spoke Alloy Wheels (135) & RFT's, M Sport Steering Wheel, Sports Seats, M Door Entry Sill Trims, M Sport Suspension Settings, M Aero Bodykit I | Pro NAV | Bluetooth Prep | Xenons | Adapative Headlights | Headlight Washers | HUD | PDC | Automatic Air Con - Advanced | Automatic Tailgate Operation | Heated Front Seats | Sun Protection Glass | Non-Smoker Package |
Originally Posted by anit999' post='318314' date='Aug 2 2006, 10:11 PM
Is anyone selling copys of the completed satnav DVD with speed camera POI ?
Does anyone offer these 'ready made' DVD's?
Old Aug 9, 2006 | 07:32 AM
  #150
Andy E61's Avatar
My Ride:
Hi Mathmos,
Hope you had a nice holiday..?
I am using NERO Reloaded v6 to burn the DVD.
All seems to correct as the files are on the disc as they should be, but when I insert it into the drive
then there is no recognition and it contiues to call for the disc.
I realise that you are being inundated by requests for assistance - once I can get this sorted then I
will be able to make my own updates as and when required.
Thanks for your assistance.
Kind regards
Andy
